#21 | |
MM's official Chevy guy
the recorde is 660rwhp
![]() "Speak softly and carry a big stick" - Theodore Roosevelt "Any idiot can make a V8 fast, it takes a real idiot to make a fast V6". ![]() '02 Mustang N/A 4.3 stroker away for winter '72 Chevelle project car 454 coming '93 Bronco EFI 351W DD Last edited by whitemustang02; March 13th, 2008 at 12:07 PM. |
#22 | |
1998 Mustang V6 5 spd.
a better cam!
#23 |
visit Harrison Porting |
My car ---- (m112 in progress) |
#24 |
and what would the best flowing heads be? split port or single port?
#25 | |
¡ʇsnq ɹo uʍop ǝpısdn
but after market wise im not sure, what ever money can buy ... that would be the best heads
#26 | |
drag racing & the split ports have better throttle response throughout the RPM range for street.
#27 |
wheres torres when ya need him...
#28 |
![]() iTrader: 1 reviews
you would have to get a tune whe you do this anyways. the maf will be screwed up because its sensing to much air coming in that its not used to. leave stuff like porting to the professionals anyways, they know what they are doing and sometimes when you do porting yourself you can actually lose hp because you grind things off that you actually need.
#29 | |
as far has most power that is FALSE
#30 | |
as far as performance goes Gary's car showed that split port is BEYOND clearly the way to go
sorry single port guys...matts car is impressive but next to garys its a tear drop down matts face IMO Matt probably has the BEST possilbe heads on his single port but with 28psi he still cannot touch Gary ON FULL RACE GAS AND TUNE Gary, split port, custom upper just like matt...half the boost MORE power, mix gas.. the heads and intake flow better on the split port.
some of this is FALSE such as the tunning if anything the MAF might be reading less then what the cylinder is used to getting. either way the MAF should adjust and read correctly. with a tune i can adjust my car from say i was tunned at 8psi. i can go to 4psi, 6psi, 8psi and 10psi no problem and thats MUCH bigger air pressure that the sensor is reading over an N/a motor as for porting IF you ported to large the its beyond gasket size you will LOSE power and blow gaskets and poor shape will include poor flow or to much turbulance in the flow decreasing power rather then earning any
Threads Similar to: porting?
| Porting and Polishing | RandoGT | 96-98 | 37 | August 19th, 2007 09:44 PM |
| Porting Question | mustang_s | Modular Mustangs | 0 | August 1st, 2007 11:03 AM |
| Porting for a 97 Mustang GT | mustang_s | Modular Mustangs | 1 | July 26th, 2007 12:25 PM |
| porting | stang638 | V6 Mustangs | 1 | May 25th, 2007 02:12 PM |
| Porting | scxc15 | V6 Mustangs | 3 | May 10th, 2007 09:53 PM |
