Emergency, Mustang Down - Page 2
Old March 15th, 2008, 02:14 PM   #21
2002 mustang
diesel88 is on a distinguished road
Send a message via AIM to diesel88
no my wheels did not lock up, i just hear very loud poping noises.
Old March 15th, 2008, 02:18 PM   #22
mustang1072's Avatar
mustang1072 is on a distinguished road
Send a message via AIM to mustang1072 Send a message via MSN to mustang1072
Originally Posted by GreenFaleen View Post
no he doesnt have t-lok, but he probably screwed up his spider gears, time for an 8.8
agreed.. i trashed my 7.5 about 3 months ago.. it sounds like ur grinding up ur spider gears..
Originally Posted by Onemanzu
your moms a quicky... ha just playin ... but seriously
Originally Posted by mustanginky View Post
.... felt great in the seat of the pants dept.
2002 Ford Mustang GT
And so it begins... (mods)
Old March 15th, 2008, 03:06 PM   #23
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
it might at some point though then it will pop and squeal, and get 4.10
NCMM #9
Old March 15th, 2008, 04:17 PM   #24
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
Did you guys do this while you were racing? How did it happen. I know you were gonna race again. BTW why do you think diesel has a t-lok? I know you keep saying he does, but unless he put one on...he doesn't.
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old March 15th, 2008, 05:06 PM   #25
2002 mustang
its DEFF my spider gears for sure, i opened the back end up and found my teeth broken off and it just looks like a disaster. any clue where i can find the cheapest place to buy good quality spider gears?
Diesel
Old March 15th, 2008, 05:08 PM   #26
2002 mustang
t lock b/c both of my tires spin lol, and also no this was not done raceing, i was just going down the rd last night and all of the sudden i hears BAM clunk clunk clunk, so i pulled over thinking wtf now! and today i found out that its my spider gears after all ugh. i have spent so much money on this stang its getting really pointless.
diesel
Old March 15th, 2008, 06:33 PM   #27
eBay Motors: Ford Mustang Racing 4.10 7.5" Gear Set V6 3.8 (item 280207444783 end time Mar-16-08 00:22:31 PDT)
Old March 15th, 2008, 07:49 PM   #28
2002 mustang
i dont need that gear i need the spider gears.
Old March 15th, 2008, 10:02 PM   #29
MM's Resident Ricer
2006 Scion tC
13.001@113
if both your tires spin you need to make sure you dont have an 8.8 or t-lok installed you need to figure out what is in your car and then we can tell you what to fix
oh btw my guess is burnt up or low gear oil, which makes me think the guy who had your car before did a ghetto t-lok and gear install.
NCMM #9
Old March 15th, 2008, 11:57 PM   #30
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
Diesel
show a picture of the rear
im highly doubting you have a posi or 8.8
a stock V6 will not tear up spider gears unless your doing something rediculous. shit it took me over 300rwhp to break my posi with drag tires at a track
let alone 160rwhp or less since its auto, street tires on the street.
[SIGPIC][/SIGPIC]
Acmillr loves me
Old March 16th, 2008, 12:40 AM   #31
tsp_2177's Avatar
2005 Civic
GAY!
tsp_2177 will become famous soon enoughtsp_2177 will become famous soon enough
Originally Posted by dgt_mustang View Post
diesels mustang is sitting on my lawn right now, everytime the car turns there is this popping noise from the rear end, usually its only when he turns the car but if he holds the brake and presses the gas, then it will do it to, i was thinking something like driveshaft is broke or the gears got broken, hes got traction control on the car so i think that means he has both wheels spinning right? also we took the plug off the rear differential and there wasnt alot, but a little bit of tiny metal shavings on the magnetic end.
if the driveshaft was broken the car wouldn't be making a popping noise when turning
it wouldn't be turning at all lol
due to the lack of forward movement
slow car member twinky times two
the stangs gone
pypes mid muffler catback with their X-pipe
In the top 20 cool peoples list on MM
potsticker in training
Old March 16th, 2008, 09:11 AM   #32
stephen has a spectacular aura aboutstephen has a spectacular aura about
The V6 Mustang comes with a 7.5 which is not a limited slip differential. I believe by t-lok you mean limited slip. The 8.8 is limited slip, which means there are clutches that limit the relative motion between the two drive shafts. Popping noises sound like problems with the clutches if you have t-lok in this car. If it's a 7.5 then it's probably the gears in the carrier (same as spider gears I think.)
It is possible to remove the differential gear carrier and replace the carrier gears, bearings etc. It is necessary when you put it back to be sure that the ring and pinion gear remain properly aligned. It might be posible to install a used gear carrier to fix the problem. (I would transfer the ring gear you have.) A new ring and pinion set is expensive; however, if you reuse the original ring and pinion with other new parts you may increase axle whine.
Old March 16th, 2008, 12:34 PM   #33
MM's Resident Ricer
2006 Scion tC
13.001@113
t-lok is what ford called their lsd
NCMM #9
Old March 16th, 2008, 02:36 PM   #34
2002 mustang
DGT will post a pic of the rear end and the broken gears.
Diesel
Old March 19th, 2008, 02:06 PM   #35
Diesel
I'm not sure where to buy the gears. Probably from Ford.
I would recommend that you remove the gear carrier and replace all 4 of the gears with new ones (there are 4 gears, 2 vertical and 2 horizontal, in mesh with each other). In removing the gear carrier carefully note the number and position of shims so you can get the gear carrier back in the same place. Then the ring and pinion adjustment should still be about right. You might also replace the bearings on the gear carrier if they are worn.
That should get your car running again.
Old March 26th, 2008, 01:18 PM   #36
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
ill tell you how diesel broke those gears, he put the car in revers a couple times then slammed into drive,
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old March 26th, 2008, 02:02 PM   #37
crashnebula's Avatar
2000 Mustang v-6
crashnebula is on a distinguished road
i cringe at the thought
2000 V-6 Coupe Mustang, 17 inch rims, custom hood, exhaust is done!!
Old March 26th, 2008, 02:08 PM   #38
Trance's Avatar
2004 mustang
14.8
Trance is on a distinguished road
Send a message via AIM to Trance Send a message via MSN to Trance Send a message via Yahoo to Trance
oh fun!
Threads Similar to: Emergency, Mustang Down
Emergency Room Rant. Genevieve! The Clubhouse 35 March 9th, 2008 10:48 PM
Help!!! Emergency!! A Squeak!!!! dgt_mustang V6 Mustangs 24 January 3rd, 2008 07:47 PM
Emergency Brake WAR-PARTY The Clubhouse 4 December 16th, 2007 12:07 PM
*Emergency* on my DD noob All Other Vehicles 26 August 6th, 2007 12:39 PM
Emergency!!!!..............................Brake flames_blue V6 Mustangs 15 April 12th, 2007 08:28 PM
