radiator mishap....ASAP HELP
Old March 16th, 2008, 12:43 AM   #1
94v6blkndred's Avatar
02 Turboed Saleen Clone
faster than my v6
94v6blkndred will become famous soon enough
Send a message via Skype™ to 94v6blkndred
Jademetals 98 started running like shit at idle so i figured we had better head home before it decided not to work but in the process overheated and poured steam so i was forced to pull over. I noticed it was steaming and losing coolant from the left side of the radiator(opposite of the cap).I cant tell exactly where and how big the crack or what not is..we ran to wal mart in my car and got some distilled water, antifreeze,and some radiator sealant...went back and checked it...the overfill tank and radiator was completely empty...filled it up...put the sealant in and got it started to make it the two miles we had left for home...i let it idle like the bottle said and it maintained good temperature and finally quit steaming...i went to take it around the block and it heated as soon as i put it in reverse and it made a grinding noise like the engine was too hot...i immediately parked it and checked...the radiator cap wasnt hot at all so i pulled it off and checked..the coolant level had dropped significantly so i dont think the fluid was making it to the hose going to the thermostat because the leak is under that.as soon as i poured more water into it, it steamed up then dropped down again and pretty much evaporated out of the side....i also noticed it wasnt pulling in any coolant from the overfill tank...sooo....Since i dont know how bad the damage is and were broke...can i try to run more sealant in it or do i have to get a new radiator? You think maybe the cap is bad so its not pressurizing the system properly to pull the coolant over??How hard is it to replace a radiator and where can i get one for a good price? I also think her thermostat was going out but i dont know if that is relavant to this problem...sorry for the long post i just need to figure out since we both have jobs and have school....thanks guys!
Old March 16th, 2008, 12:45 AM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
those sealents are OK fixes but they clog things up, you need a new radiator and f the crack is as big as it sound only sealant i can think of that would help would be blue devil and its 60 bucks a bottle, but it will fix anything including head gaskets
Universal Products, Inc.: Blue Devil Product Overview
NCMM #9
Old March 16th, 2008, 12:46 AM   #3
faster than my v6
60 bucks is still cheaper than 200 for a new radiator....plus i think my apartments have a rule on doing auto work out here so i dont even know if i can put the radiator in..but idk if i can take it anywhere cause it sounds like hell when it runs like its not gettin fluid.
Old March 16th, 2008, 12:48 AM   #4
MM's Resident Ricer
2006 Scion tC
13.001@113
go pick up a bottle at autozone stuff is amazing just follow the directions really closely and get a couple extra gallons of coolant
NCMM #9
Old March 16th, 2008, 12:49 AM   #5
faster than my v6
alright ill have to do that then....it seemed like it sealed up kuz it quit steaming but then when i tried to leave it started rollin out steam again..
Old March 16th, 2008, 12:50 AM   #6
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah alot of those cheap sealers will crack under high heat i have seen radiators almost split in half sealed with this stuff
NCMM #9
Old March 16th, 2008, 12:51 AM   #7
faster than my v6
word thanks bro i appriciate it...my dad was sayiing to JB Weld it but i cant pin point the crack cause its in an awkward posistion.
Old March 16th, 2008, 12:55 AM   #8
MM's Resident Ricer
2006 Scion tC
13.001@113
no problem man
JB will weld the cooling channels together so that could be bad, usually works on the plastic parts not the core, but blue devil will seal any of it and it has a money back garente (sp??) so if it doesnt work they will refund you
NCMM #9
Old March 16th, 2008, 02:19 AM   #9
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
IDK man...If you have a radiator problem I'd say go ahead and replace it. I know for a fact that a bad radiator can warp your cylinder heads. Then you're looking at over a grand. Better to just go ahead and replace the radiator. Cuz driving around with a bad one can fuck things fast.
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old March 16th, 2008, 02:36 AM   #10
stang300a's Avatar
2004 Mustang V6
stang300a is on a distinguished road
i agree. if i was u i would just replace the radiator.
2004 Mustang 3.9L V6 with K&N intake, Dual Flowmaster Super 40s, Motoblue 42% Pulley, GT rear sway bar, drilled and slotted rotors, SCT tuner, Black FR500's 17 by 10.5 and 17 by 9, 4.10 motive gears and FRPP T-Lock.
Old March 16th, 2008, 03:12 AM   #11
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
looks like jade might want to consider doing some ... uhh better photo shoots if you catch my drift... she is 18 right?? ... take it off!!
(tell her i said this )
much love
-omz
Old March 16th, 2008, 08:34 AM   #12
stephen has a spectacular aura aboutstephen has a spectacular aura about
The radiators on these cars have an aluminum core with plastic tanks. The plastic tanks tend to crack and I don't think any sealant would fix that. You probably need either a new tank installed or a new radiator.
Threads Similar to: radiator mishap....ASAP HELP
CCRM mishap shaken'bake 94-95 5 May 5th, 2012 02:52 PM
radiator Jucostud 96-98 3 February 27th, 2008 01:35 PM
Radiator V6boi V6 Mustangs 12 October 30th, 2007 02:23 AM
Radiator javier351lx 5.0 Mustangs 2 July 11th, 2007 04:31 PM
94 GT radiator stang94 5.0 Mustangs 3 December 14th, 2006 05:17 PM
