Headlight Change Question
How hard is it to change the headlight's?
1999 Ford Mustang V6
14.79 @ 92.15
on 94-98, you have to remove the headlights and taillights separately by 3-4 bolts
RLY SRS
Its not a hard job...Just tedious...
If you want to make it easier get a Chilton's Book on your Mustang... It will come in handy many times over... |
i dont know about your car but i did mine a while ago, (not change them but take them out to see somthing) i did the front head lights, and rear in no time. its fairly easy
14.79 @ 92.15
it is different on the headlights for 94-98 as opposed to 99-04 due to one piece with clips on newer and 2 piece with bolts on older
2003 Mustang GT
assuming the headlight mounts the same as a 95 it should be gravy. theirs 1 10mm nut that holds on each corner light, remove those first. theirs this clip on each of the actual headlights that you have to remove. all you have to do then is depress the plastic tabs and pull. oh yeah dont forget to disconnect the head light from the harness before pulling
Threads Similar to: Headlight Change Question
| Gear oil Change question?? | Cantbeatblack | 99-04 | 3 | September 20th, 2007 01:00 PM |
| oil change question | juan310 | V6 Mustangs | 22 | July 25th, 2007 03:18 PM |
| one headlight | Dj1123 | Visual | 13 | May 16th, 2007 07:02 AM |
| 06 headlight!!! | Ware | Visual | 1 | May 12th, 2007 07:16 AM |
| Headlight Question? | 2000redpony | Modular Mustangs | 17 | January 30th, 2007 10:25 PM |
