Hello everyone!
I need some help I have a engine swap going on and the pats anti-theft system won't let the motor turn over. It is stopping the gas pump and the fuel injection. I got a old truck that I am putting an 04 mustang 3.8 v6 motor and transmission in. I also have the Ecu and the wire harness and all the wire plus the gauges and the plug to run codes. I also have the rear end and axle. But I don't have the KEY!
I need to bypass the pats system so the enigne will work. I have gone to ford and locksmiths and many other places but no help due to no key and no steering column to reset the Ecu.
I don't mind buying whatever I need to make this work. But it is a costly build and trying to go around buying a plug and play harness which is $800 plus. Is there another way so I can spend the money other places on the build?
I have done research and came up with an alarm system module for the car with a relay. But unsure if will work and bypass the pats or have someone tune the Ecu to bypass the pats which is hard to do without oem parts.
Can anyone help?
Can anyone help?
