I have a 2000 V-6 mustang with the Mac dual exhaust kit (cat back system). The driver side mufflers rattles against the frame because of how close the mufflers is. Does anyone else with an aftermarket duel exhaust kit have this problem and if so, what did you do to solve the problem?
Probably a loose hanger or a hanger needed that isn't there. Have an exhaust shop lift it up and see what's up. I've been there before on a few of my v6's I've had.
No, it's a brand new system. I installed it myself. It had the exact same system from American Muscle when I bought the car and the same muffler rattled too. I'm guessing it's because the V-6 stangs were never intended to have duel exhaust.
I was hoping to find someone on here that had a 3.8 mustang (99-04), that had the same problem and had a remedy for it. I've tried folding aluminum foil and placing it between the muffler and frame but it somehow always finds a way to work loose and fall out.
Dude i have owned two 2004 v6 mustangs. Between them i had 9 exhausts. Just because a new system says it comes with all you need doesn't mean it won't do better with another hanger. I had a shop add additional stiffer hangers at the mufflers just before the bend to the over axle portion to keep that rattle from being there on my last anf favorite setup. Which was borla stingers You're welcome
you can wrap the muffler or exhaust pipe in some exhaust heat wrap to try to deaden the sound if you want. That being said, I would agree that you need to get the car on a lift and you should be able to determine where it is rattling and fix it relatively easily.
Oh, I know exactly where the rattle is. I don't need a lift to find it. I bought a sheet of 1/4 inch thick industrial, high temp silicone and used a high strength adhesive and bonded it to the frame rail
More than likely, your clearances are messed up because of the angle the piping was at when you connected the mid pipe to the header and the mid pipe to the catback. Loosen the main bolts that connect these together and push the piping either up down or left or right and tighten it back down with that tension still applied. When you tighten it back up it will stay. I.e. If the muffler is rubbing on the right side next to the frame, loosen those bolts and push the muffler to the left and then retighten it.
Sent from my iPhone using Tapatalk
Related Threads
Modded Mustang Forums
6.3M posts
80.3K members
Since 2005
