V6 That Won't Stop!
Old October 11th, 2006, 09:00 AM   #1
Keir is on a distinguished road
V6 That Won't Stop!
Hi, I have a 1996 v6 auto, and was wondering if anybody could help with a problem I have as in the UK I am struggling to find anyone with american car knowhow! The problem is my car keeps running even when I pull my keys out of the ignition and have to disconnect it at the engine to stop it! I managed to get a new tumbler from a 2000 stang but the car wouldn't even start with it! Please help!
Old October 11th, 2006, 05:30 PM   #2
ssajdowitz's Avatar
ssajdowitz is on a distinguished road
Does everything else turn off with the key switch, like the radio? If not, then the problem is probably the key switch.
If that is working properly, I would check the CCRM (Contant Control Relay Module). There is a relay in there that sends power to the PCM (Powertrain Control Module). When relays fail, they either don't stay on or don't turn off.
On my 98 3.8 mustang, the CCRM is located under the passenger front fender. You have to remove the front tire and black plastic fender.
I would get an owner's manual with a wiring diagram. Then, you can find which wire is the power supplied to the PCM. That wire should only be live when the key is in the "run" position. If it is powered all the time and the key switch is good, I would be willing to bet the CCRM is bad.
Old October 12th, 2006, 09:46 AM   #3
No the radio and everything electical stays on, the actual key just swivels round in the ignition without the 'clicks', so it does sound like it could be the key switch as apposed to the tumber barrel, do you know where I may be able to find a key switch? Thanks.
Old October 12th, 2006, 03:16 PM   #4
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
yeah sounds like the key switch to me
try ebay or mustang tuning
if you cant find one i would try www.fordracingparts.com
www.moddedmustangs.com
Threads Similar to: V6 That Won't Stop!
Car Vibrates when I stop!? Systemreset V6 Mustangs 38 October 28th, 2007 07:05 PM
HMUSN, Please..STOP!! TheUNZippee! The Clubhouse 85 September 19th, 2007 04:27 AM
Stop it Onemanzu The Clubhouse 77 September 12th, 2007 02:20 AM
STOP FLOODING THE CLUBHOUSE!!! MicronXD The Clubhouse 8 August 23rd, 2007 02:14 PM
new stop sign acehole Pictures 7 February 1st, 2007 09:15 PM
