Idle Too High
IDLE TOOOOO FAST
2001 3.8 V6 IDLES TO FAST AT START UPS AND IN PARK OR NUETRAL IDLE IS NORMAL WHILE IN DRIVE OR REVERSE
how is the idle to fast? ....i understand to high but fast?
could be a computer problem, id take it to ford
iT IDLES AT 2G IN PARK AND NUETRAL..
SORRY ...MAYBE I SHOULD HAVE SAID HIGH..IT IDLES AT 2G
AT START UPS PARK AND NUETRAL |
2g?
....2000rpms? most likely a computer problem and its reading something wrong also caps is not need for every letter... 2000 rpms is way high, someone had this problem a lil while ago and went to a place, i bet its the ECU reading somthing wrong
SORRY ABOUT THE CAPS PC CAPS LOCK STUCK!!!
no prob, find a place that will do computer work on the car
im not 100% sure thats it...just 80%..i dont see what else it could be its not oil, any kind of filters or w.e
2003 Mustang GT
try cleaning your iac valve first also check for vacuum leaks before you go spend a bunch of money
70mm t/b, plenum, cast intake manifold, full magnaflow exhaust, JLT cai, FRPP c springs, anti roll kit, steeda upper control arms, custom tune, subframe connectors, HID headlights, mach 1 chin spoiler |
1999 Ford Mustang V6
does it only idle fast on startups, once it is up to temp what is the idle rpm? does it fluctuate at all? fast/high idles can be a problem of vac leaks or airflow related sensors. do you have a CEL showing, go to your local autozone and get them to scan it for codes, it is free. they will plug in a handheld and scan via obdII port and tell you a code that you can post here. do you have an aftermarket oilable airfilter, sometimes over oiling will cause MAF issues. you can try looking at your IAC. did you do any recent mods, look over the vac hoses and snoop around the intake manifolds to see if you have a leak in the gaskets?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
14.79 @ 92.15
if the idle fluctuates, you probably have a vaccuum leak somewhere in the intake tract. if it is just high, it could be a bad IAC or a few other sensors. ideal idle for an auto is 900rpms in P or N, and 800 in D or Gear
IAC? i could see if hes stalling but hes reving high...i dont see what IAC has to do with
#13 | |
14.79 @ 92.15
could be stuck, from buildup
2003 Mustang GT
the IDLE AIR CONTROL valve adjusts the throttle plate at idle. if the spring inside is stuck, has debri in it, gummed up it will cause a varying number of problems. it might not be the iac it could also be a vacuum leak like i already said
Threads Similar to: Idle Too High
| high idle | RAMS#20 | 94-95 | 4 | October 24th, 2007 03:23 PM |
| high idle then nothing | msolaas1 | 2005 - 2010 | 4 | October 10th, 2007 06:42 AM |
| High idle | 8A_Honda | 5.0 Mustangs | 16 | September 17th, 2007 08:53 PM |
| high idle | buddie | 94-95 | 1 | June 30th, 2007 03:40 PM |
| Idle Too High | terribleonexx88 | 5.0 Mustangs | 28 | October 16th, 2006 12:27 AM |
