Discussing Debating Eibach-Pro Kit or Sportline. in the V6 Mustangs Forum. I've been looking into coil overs and heard about them, but know NOTHING about ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
#22 |
MM's official Chevy guy
2002 Mustang V6
and what they do is put the spring around the shock. this gives you a stiffer ride ans well as the ability to adjust the spring hight. |
#23 | ||
![]() Benefits: 1. Better force geometry means you can increase the wheel rate (essentially, handling) while actually LOWERING the spring rate. 2. Because conventional location springs are ridiculously heavy (~11lb compared to ~5lb for the new hardware AND spring), you lower the total unsprung weight by a significant margin, and therefore have better handling AND better ride (assuming you don't go crazy with the spring rate). 3. Because the lower spring perch is now on a threaded cylinder, you can adjust the height of your car to virtually whatever your heart desires. So, those are 3 of the big advantages... Of course, there are others, such as overall weight loss, allowing you to run perchless A-arms, etc. There is an increased cost associated with going to coilovers in the first place, but it's worth it, IMO. Something to consider, at least.
1993 2.3L Coupe [Motortopia] : Open-Track Project... 214k miles 2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP) 2001 Harley Davidson F-150 Acts 16:31 |
#24 |
-5-Speed -BBK CAI -UD Pulleys -BBK 70MM TB -Mac O/R H pipe -Trick Flow Plenum -Yokohama AVS ES100 Tires -UPR Blue Thunder Short Throw -Magnaflow Magnapack Catback |
#25 |
#26 | |
2002 Mustang V6
the reason as to why i haven't lowered my car was when i was looking a springs i then found coil overs and decided that they would be much better and decided to go with them. however haven't saved up the money to get them yet. |
#27 | ||
Mod Johnson
2004 Mustang V6
TURBO on 7.2psi CHECK OUT MY WEBSITE |
#28 |
#29 |
1995 Mustang convertible
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
#30 |
2002 v6 vert
sportline |
#31 | |
Mod Johnson
2004 Mustang V6
#32 |
#33 |
Threads Similar to: Debating Eibach-Pro Kit or Sportline.
| eibach sportline kit | shadow5403 | V6 Mustangs | 6 | November 13th, 2008 09:25 PM |
| eibach sportline lowering springs | 99blkcobra | 4V / SVT | 7 | March 4th, 2008 10:31 PM |
| wtb: eibach sportline springs | Drgnracin72 | Want to Buy | 9 | February 8th, 2008 02:08 PM |
| Eibach: Sportline or Pro-kit? | RAGEman | 99-04 | 21 | December 8th, 2007 04:18 AM |
| eibach sportline or pro kit | BlackIce | Suspension | 2 | February 23rd, 2007 05:39 AM |
