Discussing 2002 Mustang rear end break down help??? in the V6 Mustangs Forum. I need to find simple break down of a stock 2002 mustang rearend. I dont ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2002 mustang
2002 Mustang rear end break down help???Diesel |
SP00LIN V6
2000 Mustang V6
unknown @390
this is alot of explaining with out pictures if your just replacing the spider gears you wont need to remove the case itself which is good take off the cover let the gear oil drip in to a pan you'll probably need a screwdriver to wedge the differential cover off next rotate the case until your able to get to the bolt that hold in the pin in the case(case being the posi or open carrier) take out the bolt slide out the pin get a magnet to pull the c-clips off the axles pull the axles next hold the ring gear and push the spider gear or side gears till you can pop the spider gears out then replace the spider gears and work backwards
![]() 437rwhp and 402rwtq through a V6 on a stock bottom end
2002 mustang
Diesel |
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
![]() Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS MM 4 Banger club: Senior Ricer "Horsepower sells cars, torque wins races." -Carroll Shelby Thanks To My Sponsors: Strup Performance |
2002 mustang
Diesel |
SP00LIN V6
2000 Mustang V6
unknown @390
then 2 side gears that the axles slide into
2002 mustang
thanks Diesel |
#8 | |
SP00LIN V6
2000 Mustang V6
unknown @390
thats by far the easiest part of the job the whole thing is pretty easy IMO
Free Online Manuals and if you don't want to spend $ on a book, try a library... there has to be plenty of automotive books there |
#10 | |
You might consider getting a used rear axle or at least the gear carrier and gears. If you replace just the gear carrier portion, I would use the original ring gear. |
2002 mustang
Diesel |
91 Sonic Blue Goodness
19.83 @ 12mph
Threads Similar to: 2002 Mustang rear end break down help???
| Right rear break dragging | mp4 player | V6 Mustangs | 3 | February 11th, 2008 01:11 AM |
| Someone Tried To Break Into My Mustang | White 89 | 5.0 Mustangs | 23 | December 11th, 2007 05:11 PM |
| Break my rear Axle | EZ8911 | 2005+ | 18 | April 20th, 2007 10:52 PM |
| Rear Break Issues | EmeraldSVT | Modular Mustangs | 2 | October 2nd, 2006 04:52 PM |
| 2002 Mustang GT rear disc brake Question | lucidsoul5 | General Tech | 6 | July 24th, 2006 05:21 PM |
