V6 Mustang Detonating
Old October 14th, 2006, 11:21 AM   #1
Look Ma! My First Post!
eagleuh1 is on a distinguished road
My wifes mustang is starting to detonate real bad, even under light loads, such as flat ground and light acceleration. She usually runs regular grade gas. I have her putting high test in until I can have the time to check her car out. It has 55,000 miles, 2000 model. Do these cars have knock sensors to retard timing when they detonate. If so a bad one might let this happen. What should I be checking? Thanks
Old October 14th, 2006, 11:51 AM   #2
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
Don't know anything about a knock sensor, but just check the timing, and go from there to retard the timing.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old October 14th, 2006, 12:09 PM   #3
mdvaldosta's Avatar
11.47@120.58
No they don't have a knock sensor, only the DOHC engines do. It could be bad formulated gas or some other things (related to stuff that shouldn't be an issue on a stock engine).
Sometimes carbon build-up in the chamber area over time can cause an effective raise in compression ratio - hence needing to higher octane fuel. You could also try running a set of plugs 1 heat range cooler than stock. If the detonation is slight, doing this should fix the problem and allow you to run regular gas.
Threads Similar to: V6 Mustang Detonating
2001 mustang 5 speed vs. 2005 mustang auto. DannyStu Drag 20 October 6th, 2007 10:55 AM
MUSTANG CLUB OF INDIANA.... MUSTANG SHOW AT THE SPEEDWAY!!! mustangmanic Midwest 0 June 27th, 2007 08:48 AM
So Md Mustang Club 3rd Annual Mustang & Ford Show Hwyman Mid-Atlantic 0 August 8th, 2006 03:39 PM
