Removing Old Plug Wires
Old April 8th, 2008, 01:32 PM   #1
modded232's Avatar
2000 Mustang V6 Vert
modded232 is on a distinguished road
I am in the process of removing my old spark plug wires and coil pack, and I can't seem to figure out how to get the wire clip between the engine and firewall off. I can only see the part where the wires pass through, but can't see the rest. Anyone know how I can get this off? (I'm almost at the point of just cutting my old wires in half and pulling them out)
And also, I was thinking about running the new wires overtop the intake manifold at the very rear side. Would the intake manifold get too hot to do this? or will it be fine? Thanks.
Old April 8th, 2008, 01:45 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
you just need to get the line out of the clip?
pop it up
NCMM #9
Old April 8th, 2008, 01:49 PM   #3
modded232's Avatar
I'm having a hard time getting my hand and a screwdriver back there and still being able to see what I am doing. I'll try again after I eat a bit of lunch. Does the intake manifold get hot enough to be bad for the wires over a long period of time?
Old April 8th, 2008, 01:57 PM   #4
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
No, they should be fine if you bought a high performance ignition wire.
Old April 8th, 2008, 02:23 PM   #5
stephen has a spectacular aura aboutstephen has a spectacular aura about
There is a plastic wire clip underneath the upper intake manifold. It is pushed onto a stud bolt in the back of the lower intake manifold. It will be much easier to route the wires if you remove the upper intake manifold. I would route them exactly as stock with all the insulators etc. in place. The important thing is that they not touch the exhaust manifolds.
Old April 8th, 2008, 03:10 PM   #6
shadow5403's Avatar
mine are touching and have not melted, or shown any deterioration cause from heat. Im using the JBA powercables.
Old April 8th, 2008, 04:57 PM   #7
modded232's Avatar
Okay, I managed to get that rear clip out. Wires and coil pack are in and working fine. Thanks for the help.
Old April 9th, 2008, 08:41 AM   #8
shadow5403's Avatar
curiosity....why didnt you spend the few extra bucks and changed the plugs why you were in there?
Old April 9th, 2008, 09:14 AM   #9
modded232's Avatar
I did them 3 or 4 months ago. I probably should have pulled them out and checked how they were doing, but it's too late now. I'll check them when I replace my leaking exhaust manifold in a couple weeks.
Threads Similar to: Removing Old Plug Wires
spark plug 8mm wires dgt_mustang V6 Mustangs 23 January 29th, 2008 12:35 PM
plug wires whitemustang02 V6 Mustangs 20 September 22nd, 2007 12:21 AM
Which plug wires are the best? MonsterSD 5.0 Mustangs 11 June 22nd, 2007 12:26 PM
Plug wires 97_4.6L_Stang 96-98 4 February 16th, 2007 09:16 AM
Spark plug wires SPF0percent V6 Mustangs 5 February 7th, 2007 11:16 AM
