How To Make My 99 V6 3.8l 5-Speed Faster?
does anybody have a clue on how to make the 99 v6 faster..i've been reading these forums day after day..but i cant find anything for the 99..so could you guys please help thanks...oh yea does anybody think a twin turbo set up on the v6 is better then the s/c?? and cheaper??
...i already have a cai...and exhaust set up too..
48.47@ 12.58
welcome to the forums.
99-04 is basically the same mustang so all the tech you see is valid towards your 99. a TT will make more power but it is much more expensive and harder to tune
MM's Resident Ricer
2006 Scion tC
13.001@113
what kind of budget do you have? And 99-04 like Hmusn said is the same car pretty much. And a single turbo is probably more efficient
1995 Mustang convertible
+1 listen to Doc he's the man. I plan on a TT setup. However, if you're going to do that then you need to get a built motor. A 4.2L stroker will make you a lot faster. If you don't want to go that route a single turbo and a SC are near the same price range. I personally think the turbo is a better system of boost, but you should do your research and decide which one you prefer. There are also several MUCH less expensive mods that will make you less dramatically faster. Some examples are a tuner (go with SCT or Sniper), 4.10 or 3.73 gears, t-lok, UD pulleys, ported and polished intakes and heads. There are others all well. The other thing to consider is N20. It is a very cheap way to see a dramatic power increase. The only problem with it is that it is only temporary power, and you need to make sure that you don't over use it. I hope this has been helpful. I'll try to answer any other questions that you might have.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
well i really don't have a budget yet... Im just looking around for stuff.. thanks for all the help... so one turbo charger...um ok... would i be just one big one..or small one...because i've been reading about them.. and i was going to put one small one in and a big one in...and i herd some where...that i could use a t-bird in take and gain like 50 horses is this tru??
oh yeah and welcome to MM!!
It depends what you are looking to do with your car. s/c or turbo are both great power adders to the V6.
#8 | |
[8MINUS2]
thanks ya glad to be here.. and thanks 4 the help!!
ok...well im looking to make my car pretty quick..around 300 to 400 hp! im planing on buying ud pulleys...and a t lock...and of course a tunner!! |
48.47@ 12.58
you can get a tuner from me.
it comes with 2 years of free retunes..
The stock motor can safely take between 6-8psi 10 psi is bleeding edge...No one is going to do a twin setup with boost that low. It would be pointless. You could just use a single turbo for less money and less headache. So yeah for a TT setup with boost between 15-20psi...yes you do need a built motor.
cool how much..?? and what do i need..because im new and im learning about cars..im going to school now...UTI
48.47@ 12.58
feel free to click my sig
when TMA made twin turbo kits they were around 6.5k i believe...dont quote me on that tho
That is unless you want to shoot a rod through your hood when you slam on the gas.
ok... well im looking to custom build a twin turbo set up...but i might just stick with one till i get a building motor
Unfortunately they don't make them anymore. You'll have to have one custom made. However you can get a single turbo kit for about $4K.
as you guys say stroker motor...how would i make a motor a stroker... (newbie)
PM itschristorres8. He can give you all the info that you need.
ok thanks... does anybody know if i could but a 6- speed trans in my car?? do i have to get the built motor first..or can i convert my 5 to a 6.??
Threads Similar to: How To Make My 99 V6 3.8l 5-Speed Faster?
| Want To Make My 3.8 Faster | 03stang | V6 Mustangs | 32 | November 20th, 2007 12:02 AM |
| How Much Faster Will A 4.10 or 3.73 Make Me | rocket | 5.0 Mustangs | 90 | June 27th, 2007 01:42 AM |
| how can i make my car faster? | villatic | V6 Mustangs | 36 | April 4th, 2007 11:27 AM |
| need to make my 1/4 times faster | punkafi888 | V6 Mustangs | 14 | February 4th, 2007 01:53 PM |
| How can I make my car faster? | V6RedMustang | V6 Mustangs | 23 | January 14th, 2007 10:59 PM |
