Clutch Help
Old April 8th, 2008, 01:56 PM   #1
rollin_loud is on a distinguished road
Clutch Help
ok i searched it up and couldnt find anything to save my life...but does anybody know of a good clutch removal writeup? I'm havin trouble getting the top bolts off the bellhousing...any suggestions as to how i might do it?
Old April 8th, 2008, 02:05 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
DDDTV - '03 Mustang Cobra Spec 3+ Clutch Install - LiveVideo.com
Old April 8th, 2008, 02:17 PM   #3
stephen has a spectacular aura aboutstephen has a spectacular aura about
If it is similar to the automatic, the two top bellhousing to engine bolts are very hard to get to. I removed the upper intake manifold (so I could see them) and used a box end (combination) wrench (13 mm I believe) and piece of pipe to loosen them. I saw somewhere else a suggestion to allow the back of the transmission to come down to get access, probably from underneath the car. In that case of course have at least one other bolt on each side so the transmission doesn't fall out.
Old April 8th, 2008, 05:27 PM   #4
Thnx for all the help guys I've almost got the bellhousing off. I just have to take the starter off and then the clutch from there. Just for future reference i used a 3/8" swivel adaptor for the 13mm socket to break the bolts loose...it wasn't easy and i got a bloody elbow outa the deal but it worked!! lol now do i have any more surprises to look forward to while removing the clutch and pressure plate?
Threads Similar to: Clutch Help
Clutch I need a clutch guru nHuman General Tech 2 September 22nd, 2009 05:12 PM
Clutch Or Clutch Cable OR Shifter??? 96GtGoodz 96-98 21 July 27th, 2009 02:59 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
Stage 2 Clutch Kits Or Just Clutch Kits itschristorres8 V6 Mustangs 3 September 24th, 2006 09:15 PM
