Strange Coolant Leak - Page 2
Old April 11th, 2008, 02:27 PM   #21
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
how about you drive to your local shop and have the coolant system pressure tested?
it doesn't cost much and you'll fide your leak in a few seconds
Old April 11th, 2008, 02:33 PM   #22
work_in_progress is on a distinguished road
i had this same problem and it was the hose connecting the tank to the radiator
when it got hot it built up pressure and blew past the hose
i donno if ford origanally put a hose clamp on it but there wasnt one on mine quick fix
oh and the head gasket thing is true too when mine went it belched coolant but you would know if it was a head gasket due to the performance hit, water in the exhaust, coolant in oil, vice versa
1995 V6
true dual
umm......DIABEETUS!!
Old April 11th, 2008, 04:49 PM   #23
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
Where is this bleed plug? Anhow exactly do I clear out air...and btw my coolant is still green, just cant keep it in
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old April 11th, 2008, 05:14 PM   #24
stephen has a spectacular aura aboutstephen has a spectacular aura about
The bleed plug is located in the top front of the engine. It's on a coolant bypass tube that connects between the water pump and the back of the intake manifold. It's a pipe thread plug. When the engine is cooled down you can take the plug out and add coolant either through there or the radiator. If the plug is out it allows coolant to completely fill the system.
Old April 11th, 2008, 06:21 PM   #25
2000 V6
I do this with the car off right
2000 V6 vert
Old April 11th, 2008, 06:21 PM   #26
2000 V6
and a pic would help too lol
2000 V6 vert
Old April 11th, 2008, 11:32 PM   #27
2000 V6
Bedtime bump...and is that plug on teh left or right side, and where is the water pump
2000 V6 vert
Old April 12th, 2008, 12:01 AM   #28
1996 ford mustang
theyanks904 is on a distinguished road
i had a problem like that 2 theres a thing called the draincock on the bottom right if your laying on your back see if thats broken
Old April 12th, 2008, 10:09 AM   #29
Look here and at the caption.
http://s290.photobucket.com/albums/l...ginedetail.jpg
Yes bleed it with the engine off.
Old April 12th, 2008, 04:35 PM   #30
2000 V6
Ok so I added coolant with the drain plug open and caught it dripping immediately after from the bottom of the radiator...luckily I have a lifetime warranty on it from auto zone
2000 V6 vert
Threads Similar to: Strange Coolant Leak
Coolant leak question?!? Mike Johnson V6 Mustangs 5 March 11th, 2008 10:50 PM
Slow Coolant Leak Ugmul 99-04 3 February 4th, 2008 11:09 AM
coolant leak? shadow98gt 96-98 3 May 14th, 2007 02:59 PM
Coolant leak? shan 96-98 12 April 26th, 2007 08:52 AM
Coolant Leak Help garyvang 5.0 Mustangs 13 May 11th, 2006 10:55 PM
