2000 Mustang v6
Window problems
Hey guys, i got a problem with my driver's side window. I have a 2000 v6, and i was pulling it out today and i turned the battery on for a second and the window wouldnt roll down. I turned the car on and then it rolled down. I was about to wash it so i needed to roll it up but even when i turned the car on and battery it still refuses to roll up. It sounds like when i push the window button down (theyre power windows) its clicking like it would roll down, but when i push the button for it to roll up it does not make any clicking noise or react at all. So im stuck with the window down and have no clue what to do. Do you guys have any ideas about how to fix it? Any help is appreciated, thanks.
![]() 2000 red v6 mustang Flowmaster Exhaust, 17x9 cobras wrapped in 255/40/17's. |
2000 Mustang v6
does anybody have any ideas?
48.47@ 12.58
you need a new switch .. they run around $70.00 from ford.
2000 Mustang v6
like the actual switch on the door panel?
48.47@ 12.58
correct.
it's very simple to get to. if you notice where you grab the door (not the handle) there will be an indentation .. just put a flat head screw driver in there and the piece will pop up. then it's 2 screws(phillips I believe) and 2 clips ( for the electric connector) to get the switch out.
2000 Mustang v6
do you have to buy a whole new switch panel or can you just replace the switch thats not working
48.47@ 12.58
you have to buy the panel.
2000 Mustang v6
i opened up the panel and took a good look at the wiring, how far down is the connector to hook up a new switch? do i need to remove the whole door panel?
48.47@ 12.58
![]() once you get that off ( the whole blue piece and nothing else) you will see 2 spots to put a phillips head screw driver.. unscrew those 2 screws and undo the electrical connections. the switch will fall out into your hand. then just bring the switch to ford ( yes ford.. it's a dealer only part) and get a new one.
2000 Mustang v6
ok i did all of that, now how do you pull out the connections? they wont seem to come out
48.47@ 12.58
use the flat head to flatten the tabs while you pull.
don't pull too hard..
2000 Mustang v6
before i take all of this off, im looking at the panel of switches, are you sure i cant just replace the drivers side window switch because it looks like it comes apart, rather than taking the whole panel of switches apart
48.47@ 12.58
yes you can replace the window switch only.. I meant you can't replace "just one button"
2000 Mustang v6
i only want to replace the drivers side switch for the drivers side window, how does that switch come off of that panel of switches
48.47@ 12.58
take the 2 screws off like I said.
then bring the panel into ford and tell them what you want replaced.
2000 Mustang v6
ok i understand what ur saying now, ill do that thanks a lot for the help
48.47@ 12.58
no problem.. I had to do it myself once.
2000 Mustang v6
well you know what ur talking about haha
Threads Similar to: Window problems
| Window Seal Problems | TDog | 2005 - 2010 | 26 | December 28th, 2007 10:14 PM |
| Window Help | mm49271 | V6 Mustangs | 3 | December 9th, 2007 09:19 AM |
| window problems | gtnate | 99-04 | 3 | March 12th, 2007 04:38 PM |
| Window Help!?!? | Arch_Angel | V6 Mustangs | 7 | February 28th, 2007 10:49 PM |
| Power Window Problems | Replica R | Audio/Video | 4 | October 12th, 2006 11:51 PM |
