Brakes!
Old April 14th, 2008, 09:36 PM   #1
mustanghollie's Avatar
2006 Mustang V6
mustanghollie is on a distinguished road
Send a message via AIM to mustanghollie Send a message via MSN to mustanghollie Send a message via Yahoo to mustanghollie
Unhappy
Brakes!
So. For some reason, I decided to replace my brake pads myself.
Not as good of an idea as I thought it would be.
All 4 brake pads went on nicely. Smooth. Quicker than I figured.
Except my right rear brake line appears to be leaking.
Not a good sign.
I'm curious as to how I change my brake lines or how do i find out if it's the brake lines.
I live in a small-ish town in Arizona called Maricopa and there's only one real good mechanic and I don't want to risk driving out to another city if my brakes are going to fail on the way there.
Any advice?
[I know this was a completely asinine thing to do; given my nonexistent mechanic history.]
Any help is much appreciated. [:
**Also, I know something is leaking because when i look at my rotor, an inch of the inside of the rotor is covered in a rainbowy, oily streak.
[[mustanghollie]]
it's more than an addiction; it's my lifestyle...
http://www.myspace.com/hishollie
"Care to take your foot out of your mouth so I can understand what you're saying? Thaaanks."
Old April 14th, 2008, 09:39 PM   #2
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
check to see if it is attached to the caliper really tight and look to see if you can find the origin of the leak. if it is leaking at the caliper just tighen it up. if it has another leak replacing the brake lines isnt that hard
edit: welcome to MM btw... post pics of the stang!
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old April 14th, 2008, 09:49 PM   #3
2006 Mustang V6
Yeah; I drove it around right after I got everything installed. and it seemed fine.
Then the next day, I drove it around for maybe a mile or two and it smelled...like burnt rubber almost.
It was weird. And I felt the rotor...nothing had freshly leaked. It just smelled like shit. Lol.
& I'll post pics of it when I got get it back from my parents'. [That's where it's sitting at the moment.]
Old April 14th, 2008, 09:51 PM   #4
muneris pro ego
97 5.0 Exploder AWD
aight cool. good luck with the brakes. and we are finally having a growing female population here!
watch out for the leg-humpers
Old April 14th, 2008, 09:53 PM   #5
2006 Mustang V6
Ha.
Thanks.
I'll make sure to keep an eye out.
Old April 14th, 2008, 09:55 PM   #6
muneris pro ego
97 5.0 Exploder AWD
welcome lol
<-- is one of the leg-humpers sometimes
Old April 14th, 2008, 11:08 PM   #7
2006 Mustang V6
LOL.
Well, I don't think my boyfriend would appreciate it much but I don't mind a good leg humping every once in a while.
Haha.
Old April 14th, 2008, 11:34 PM   #8
Avaric3's Avatar
2002 Ford Focus
slow as fuck
Avaric3 will become famous soon enough
Originally Posted by mustanghollie View Post
LOL.
Haha.
you might wanna pm zip than, hes MMs biggest leg humper
99 V6 Mustang-sold
02 Ford Focus-sold
98 Camaro Z/28-lid, catback
Old April 14th, 2008, 11:37 PM   #9
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
First off welcome to MM. Second I notice that you have an '06. How many miles do you have on it? It just seems a bit too new to be doing brake work on it already. Well, I guess if it needed it...it needed it. If you want to take it to a mechanic, I think that your brakes should hold out long enough for you to get there. Just be careful. Good luck.
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old April 15th, 2008, 01:29 AM   #10
2006 Mustang V6
Thanks!
And I've had it for over 2 years now; I got it November '05.
It's got around....I think 67,000 miles?
This is my third brake job...I've just never done it myself 'til now. Haha.
And it wasn't a good idea.
I just wanna know if i can fix it myself before I have to go to some brake shop.
They usually try to sell me a bunch of shit I don't need.
[I'm a 20 year old girl with a new Mustang and they take me for a gullible little bitch.]
So. Yeah.
Old April 15th, 2008, 01:29 AM   #11
2006 Mustang V6
LOL.
Thanks.
Old April 15th, 2008, 10:42 AM   #12
muneris pro ego
97 5.0 Exploder AWD
as i stated see if you can find where the leak is coming from. jack up your right rear and put it on jackstands and take the rim off. get someone to get in the car and press the brake a couple times. you should be able to find where the leak is coming from with that
Old April 15th, 2008, 12:37 PM   #13
stephen has a spectacular aura aboutstephen has a spectacular aura about
Replacing the pads shouldn't cause a hydraulic leak unless some of the brake lines were disconnected. If any of the lines were removed from the calipers, then the fix is new copper washers and torque the banjo bolts to about 30 ft lbs.
Old April 15th, 2008, 01:02 PM   #14
MWWarlord's Avatar
Thanks!
So. Yeah.
Wow thats a lot of mileage in 2+ years. I can see why you needed brake work now. Do as costie said. You should be able to find any leaks.
MWWarlord
Old April 15th, 2008, 01:06 PM   #15
muneris pro ego
97 5.0 Exploder AWD
gotta find the leak first before you fix it. plus the hose could have beein pinched or somehow got a hole in it while changing the brake pads, or after, hell even before then and now its noticeable.
hollie... narrow down to where the leak could be coming from. then once you find that post it up here and even with pics if you can and we can further assist you
Old April 15th, 2008, 01:26 PM   #16
RavensChild's Avatar
1998 Mustang Coupe
Amazing
RavensChild will become famous soon enoughRavensChild will become famous soon enough
the leg humpers
Zip
HMUSN
Bwal
NBA
not necessarily in that order
HARDCORE CREW
dude, be the first person in history to sue somebody for not letting you polish your dolphin while looking at porn.. you'll become a legend
Old April 15th, 2008, 01:36 PM   #17
'02SilverBullet's Avatar
'02SilverBullet is an unknown quantity at this point
Just something that could be worth checking......
Call ford to see if there is a TSB (Technical Service Bulletin) on that. Not long after I got my '02 I had the PCV valve... or whatever that damn thing is that is mounted dead center of the passenger side vavlve cover... anyway that was leaking oil all over my valve cover. I went and asked ford and they said they had a TSB on it and they would replace it for free.
Just something to check on considering your car is still pretty new.
Old April 15th, 2008, 01:53 PM   #18
muneris pro ego
97 5.0 Exploder AWD
Originally Posted by RavensChild View Post
the leg humpers
Zip
HMUSN
Bwal
NBA
I is a leg humper
Old April 15th, 2008, 01:55 PM   #19
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I'm not a leg humper.
Old April 15th, 2008, 02:03 PM   #20
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
coasties right, thats probably the best way to do it.
(i think the leg humpers would try to say they are not a leg humper in order to get closer, little sneak attack on the legs.)
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Threads Similar to: Brakes!
Need Help With My Brakes crappy_head 99-04 50 January 28th, 2009 02:03 PM
New brakes mantis3567 99-04 8 January 11th, 2008 07:14 PM
Brakes help MWWarlord V6 Mustangs 29 January 1st, 2008 04:06 AM
wat brakes? VSR13 V6 Mustangs 11 September 27th, 2007 01:41 AM
Brakes Wally1968 2005 - 2010 6 February 18th, 2007 08:34 AM
