rear end - Page 2
Old April 15th, 2008, 07:33 PM   #21
focus0frenzy1 is on a distinguished road
An 8.8" ring gear will not fit in your axle housing. To run an 8.8" you'll need the entire axle assembly. You can reuse your axle shafts and brakes as long as the rear end housing is from a 99-04 car cuz they are the same for a 8.8 and 7.5. You can use a fox body 8.8 but you will need to use 94-98 axle shafts and brakes. You can also use a 94-98 8.8 but yet again you'll need all the 94-98 stuff. The fox body and 94-98 axle housings are the same but the axles are longer cuz the 94-98 cars have disc brakes. 99-04 cars have longer axles than the 94-98 cars and they also have a longer axle housing. You can use any 8.8" rear as long as you have the right brakes and axles. If you find an 8.8 rear from a Thunderbird Turbo Coupe or Lincoln Mark VII you can use that cuz its the same as the 94-98 Mustang rearend. The Turbo Coupes came with 3.55 or 3.73 gears depending on what tranny they had. I dont know what the Lincolns had. Both cars had rear disc brakes. All 8.8's have 28 spline axles unless its from an Explorer. Explorers had 31 spline axles but you cant use the axle shafts or the rear end housing, its all wrong. You can use the 31 spline Trac Lok unit and the gears. If you use the 31 spline Trac Lok you will need 31 spline axles. Some Explorers had 3.73's, I dont remember which ones though. You can pretty much use any 8.8 from a CAR, NO TRUCK 8.8's!!!!
Old April 15th, 2008, 07:52 PM   #22
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
you said i could pretty much use any 8.8 from a car, you said any but throughout that entire post im hearing stuff that i would have to interchange.
what about just grabbing the spider gears out of the rear differential? what kind of cars out there would have the right spider gears to fit in the 02? almost all of the cars out there were 98 through 85. so if anything in that range works then thats my best bet.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old April 15th, 2008, 07:58 PM   #23
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
the axels will stick out about an inch
NCMM #9
Old April 16th, 2008, 10:39 AM   #24
2001 Mustang 3.8l
okay so i could grab ANY 8.8 off of any car (by ford) in the junyard, only problem would be that both sides of the axles would stick about?
Old April 16th, 2008, 10:40 AM   #25
MM's Resident Ricer
2006 Scion tC
13.001@113
pre 99 yes 99-04 your good, and any f-150 your good you may have to relocate some mounting tabs though
NCMM #9
Old April 16th, 2008, 10:42 AM   #26
2001 Mustang 3.8l
okay, well then maybe today im probably gonna head back up there and pull off the rear end of a crown vic v8, between the years of 91-98, thats the only years i have even been finding up there.
Old April 16th, 2008, 11:06 AM   #27
MM's Resident Ricer
2006 Scion tC
13.001@113
that one should work fine
NCMM #9
Old April 16th, 2008, 11:57 AM   #28
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
Originally Posted by MWWarlord View Post
That's total BS. the 8.8 rear can handle over 300 RWHP.
theroetically it can handle 400rwhp, but i broke mine
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old April 16th, 2008, 01:20 PM   #29
thats okay but you will have to redo the brakes i believe. I think crown vics havedrums and you need discs. I dunno about the police interceptors though
Old April 16th, 2008, 02:02 PM   #30
2001 Mustang 3.8l
okay, were gonna go to the junyard again here in a sec but i just wanna make sure i have all this stuff down
im getting the 8.8 off of a 91-98 crown victoria or a thunderbird
if it has drums can i switch the drums for my discs?
will the 91-98 be a straight bolt in and just stick out a little on the side?
Old April 16th, 2008, 02:08 PM   #31
2001 Mustang 3.8l
okay, i need to know if the rear end off of 91-98 explorers, grand marquis will fit to.
Old April 16th, 2008, 02:48 PM   #32
2001 Mustang 3.8l
this is urgent i have to leave here with a hour
Old April 16th, 2008, 03:15 PM   #33
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
if yur not putting down the power to NEED an 8.8...you dont need one
/thread
Old April 16th, 2008, 03:45 PM   #34
2001 Mustang 3.8l
im not interested in your opinion on if i need an 8.8, all i need is for a rear end that will fit the mustang, the price for both 7.5 and 8.8 is the same at my junkyard so why get an oem type when i could get the upgrade.
leave opionions like that to yourself it only aggravates this entire situation of having to find one.
Old April 16th, 2008, 06:51 PM   #35
2001 Mustang 3.8l
okay, new plan, since its so hard to find an 8.8, what year cars have the same size spider gear size? were just gonna take those out of the cars at lkq (our local junkyard). then were just put those back in there, spider gears is all he needs so mine as well.
can i get a small list of what cars between 91 and 98 have the same size spider gears?
what does /thread mean?
Old April 16th, 2008, 07:05 PM   #36
MM's Resident Ricer
2006 Scion tC
13.001@113
any car you have named minus an explorer will work, and getting used spider gears will make so much chatter its not worth it, just pull one out of a crown vic or mustang and make it fit
NCMM #9
Old April 18th, 2008, 02:57 PM   #37
2001 Mustang 3.8l
ok, couldnt find anthing in the junkyard at all, literally nothing, so i have a new plan i want to see what you guys think, i have a traction lock in my room i havent used yet, if i took my rear diff off and tried to put my traction lock in, i could just give him my open diff thats in there right?
Old April 18th, 2008, 02:59 PM   #38
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Originally Posted by shadow5403 View Post
why does everyone want an 8.8, when they have less than 200RWHP?
I was gonna ask that same question.
Because 95% of the people who want them and are going to do this and that later... never happends. Just check back in threads.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old April 18th, 2008, 03:18 PM   #39
2001 Mustang 3.8l
why bother posting opinions on something that is not the topic? go discuss that in the clubhouse,
all i need to know is if it would be smart to take out my open diff and put in my traction lock and hand over my open diff from my car to the broken car.
Threads Similar to: rear end
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 22 April 25th, 2011 03:59 PM
99-04 gt rear end into a 99 v6 glassJAw V6 Mustangs 17 February 6th, 2008 11:40 PM
rear end usspfnorman V6 Mustangs 13 November 15th, 2007 06:16 PM
need new rear end MUS-TAKE 99-04 4 October 27th, 2007 03:11 AM
Rear Rotors and Rear Axle rondaw3g0410 99-04 1 September 6th, 2006 10:00 PM
