No brake pressure
Old April 16th, 2008, 08:51 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
No brake pressure
Ok so we did my front brakes, which were bad, and now theres like no pressure The fluid is full tho am I missing something
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old April 16th, 2008, 09:03 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
bleed your brakes
NCMM #9
Old April 16th, 2008, 09:24 PM   #3
2000 V6
I thought you only had to do that if you opened up the system...I just changed the pads. Ok so how do I bleed the brakes
2000 V6 vert
Old April 17th, 2008, 11:23 AM   #4
2000 V6
Bump
2000 V6 vert
Old April 17th, 2008, 11:53 AM   #5
MM's Resident Ricer
2006 Scion tC
13.001@113
get a bleeder kit at autozone is the easiest and it is normally if you only open the system but sometimes compressing the caliper can do it
NCMM #9
Old April 17th, 2008, 12:29 PM   #6
2000 V6
Well i did compress the calipers lol...but aside from the bleeder kit whats the process of the bleeding
2000 V6 vert
Old April 17th, 2008, 12:35 PM   #7
MM's Resident Ricer
2006 Scion tC
13.001@113
pretty much open bleeder valve and keep pouring in fluid
NCMM #9
Old April 17th, 2008, 12:43 PM   #8
2000 V6
Bleeder valve...ok a quick description of where that is please
2000 V6 vert
Old April 17th, 2008, 01:13 PM   #9
MM's Resident Ricer
2006 Scion tC
13.001@113
should be on the calipers
NCMM #9
Old April 17th, 2008, 02:40 PM   #10
stephen has a spectacular aura aboutstephen has a spectacular aura about
You do have to pump the pedal a few times to seat the new pads against the rotors. Try that first.
Old April 17th, 2008, 03:57 PM   #11
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
best way to do it if you dont want to buy the bleed kit get a buddy to sit in the car
when you find the bleeder valve keep it closed.
have your friend push the pedal down 3-5 times and on the 5th time have him hold it down! and keep it down.
while its down open the bleeder vavle just enough so that the fluid slowly pours out but not with to much coming out. then you want to close the valve before you run out of fluid.
be sure to keep the master cylinder full with fluid
you want to repeat that probably like 3-4 times really until the air is out of the lines
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: No brake pressure
Alpine IVA-D310 foot brake and e brake switch ?s 97Cobra Audio/Video 2 February 2nd, 2008 07:31 PM
ne 1 know how 2 install a brake pressure guage??? 91cobra5.0 5.0 Mustangs 1 February 2nd, 2008 09:41 AM
Brake light switch problem after upgrading brake booster black88 5.0 Mustangs 2 January 20th, 2008 11:41 PM
Brake Upgrades/ SN95 Spindles and Cobra Big Brake Kits OcOnnor220 Modular Mustangs 2 July 8th, 2007 12:36 AM
Cobra brake or bullit brake upgrade 97gtstang 96-98 5 May 14th, 2007 02:15 AM
