Seafoam quick question
Alright so i was going to seafoam my car, but im changing my oil tomarrow. Would it be fine if i did it tonight and changed my oil tomarrow? and also i have about 3/4 of a tank of gas
Priest of the Car Gods
it's usually suggested that you change your oil after you do it.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
so it would be fine if i did?
MM's Database Error
Ever put seafoam in ur brake booster?
1995 Mustang convertible
I've never heard of doing that. I've heard of crank case gas tank and PCV valve.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
BTW you should change your oil within a few hundred miles of seafoaming. You may not get the full benefits of the seafoam if you don't really drive around afterwards. However, it certainly won't hurt anything.
02 ROUSH STAGE 2
1999 Mustang GT
Yeah thats what the can tells you to do!!!
Use the PCV Valve
1999 Mustang GT
no the break booster, the company advertises putting it in the break booster.
Look man use the search function to look up seafoam threads...there are like 100000 of 'em. Most will tell you to put it in you PCV valve.
MM's Database Error
if u put it in there it only goes to like half the cylinders...use the pcv just trust us
#14 | |
01 V6 convertible
too slow to try
if you look at the brake booster line, it would enter the intake on the one side and only feed those cylinders, but your PCV would enter right behind the throttle body, which would feed all 6 some cars the brake booster works, but for our intakes, use the pcv and you do want to drive about 300-500 miles to get the full benefit of seafoam in your oil, but no, would not harm to change it sooner... |
#15 | |
MM's Database Error
MM's Database Error
straight from the site>>>>
100% Pure Petroleum Use in All Engines in All Seasons 2 Cycle, 4 Cycle, and Diesels Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase thas why it doesnt make room for the v6s even tho it does the same thing
#17 | |
01 V6 convertible
too slow to try
it all just depends on how the intake manifold is set up |
MM's Database Error
shit its late i def. read that as 4 cylinder haha
01 V6 convertible
too slow to try
MM's Database Error
exactly
Threads Similar to: Seafoam quick question
| seafoam question | zinc02GT | The Clubhouse | 29 | March 7th, 2008 01:28 AM |
| seafoam question | ddashtrois | 99-04 | 13 | January 10th, 2008 06:40 PM |
| Seafoam Question? | CTown Stang | 96-98 | 9 | December 19th, 2007 02:02 PM |
| Seafoam Question | silverbullet17 | V6 Mustangs | 5 | December 12th, 2007 01:55 AM |
| Seafoam Question | ItaliStang | V6 Mustangs | 9 | November 29th, 2007 08:06 PM |
