1998 mustang V6
0.2@speed of light
gears and rear
whats the diff. in 3.73 and 4.10
and also the 7.5 rear and the 8.8 |
3.73 is 4.10 are different gear ratios.
With the 4.10s you will accelerate through gears alot faster, causing better bottom end speed, but less gas milege when floored. The 7.5 is the gear housing of a v6 and the 8.8 is the gear housing for a gt. The 8.8 can handle ALOT more power. |
And bro, calm down on all the threads. There is a search function for a reason and google is your friend.
The dif is wut transmits the power to the wheels, from the driveshaft the power goes in and then relayed at 90 degree angles to the back tires through the axles, 3.73 and 4.10 are gear ratios, higher the gear ratio the quicker the acceleration, lower the gear ratio the higher the top speed, 7.5 and 8.8 are just sizes of diffs, v6's being equipped with a 7.5 and a GT with 8.8
1995 Mustang convertible
3.73 on 4.10 are the gear ratios. a good rule of thumb is to use 3.73 if you have a manual tranny and 4.10 if you have auto. the 7.5" differential is smaller than the 8.8. because of this it is weaker. The 7.5" will break with anything over 300hp. The 8.8 can hold up to 400.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
#6 | |
1998 mustang V6
0.2@speed of light
alright my bad no more threads!
#8 | |
1998 mustang V6
0.2@speed of light
so my car has a stock 7.5 |
Yep.
Yah man you've been here less than a month and you already have more post then I do and I've been here since last year, Your better off to sit back and read and learn, take it all in. That's what I did for the longest time. Helped me tons.
1998 mustang V6
0.2@speed of light
so 7.5 can handle 4.10 gears
1998 mustang V6
0.2@speed of light
the only reason i join mm.com was to ask you guys questions!
the 8.8 wont hold much past 300rwhp and torque
theres more of difference between the 7.5 and 8.8 then just the obvious size the 8.8 has options such as 31spline and 33 spline cases you can use to hold more power
if you know yur gonna be putting that much power down....i would def get a 9" rear. They are indestructible.
Threads Similar to: gears and rear
| gears and rear end | Killer_Bee | V6 Mustangs | 3 | October 5th, 2007 01:03 PM |
| rear end gears? | 97fordsixer | V6 Mustangs | 27 | September 19th, 2007 09:36 PM |
| Rear end gears ? | theyanks904 | V6 Mustangs | 27 | June 3rd, 2007 12:17 AM |
| 8.8 rear and gears | D-Brow | V6 Mustangs | 8 | April 28th, 2007 12:10 AM |
| rear gears | 4.6gtmarine | 99-04 | 1 | March 28th, 2007 12:23 AM |
