autometer oil pressure gauge
I just install the gauge in the a-pillar pod and ran the wires thru the fire wall.
My question is can you use the sending unit that came with the autometer gauge and don't use the stock sending unit. Do i connect the two wires from the oil pressure gauge to the autometer sending unit. I hope this makes any sense. Has anyone install a autometer oil pressure gauge.
MM's Resident Ricer
2006 Scion tC
13.001@113
are you just no using your stock one at all?
Correct. I am going to use the sending unit that came with the autometer oil pressure
gauge. |
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah just disconnect the stock one then and wire in the autometer one.
Thanks. This will not disturb the computer, because i have a dyno-tuned.
MM's Resident Ricer
2006 Scion tC
13.001@113
just disconnect your battery before you start wiring anything should mess with the computer any
first off, you should have gotten a mechanical oil pressure gauge because they are much more accurate than an electrical.
Threads Similar to: autometer oil pressure gauge
| autometer temp. gauge | 5.0FUZ | 5.0 Mustangs | 12 | August 13th, 2007 01:04 PM |
| 99-04 Autometer gauge cluster | starman1950 | 96-98 | 2 | December 29th, 2006 11:03 AM |
| Autometer Air/Fuel Gauge | zeroaviation | Audio/Video | 4 | August 27th, 2006 01:38 PM |
| autometer gauge | cali 5.0 | Audio/Video | 1 | August 20th, 2006 02:46 PM |
