exhaust question (not a common one)
Old April 18th, 2008, 01:36 PM   #1
modded232's Avatar
2000 Mustang V6 Vert
modded232 is on a distinguished road
I just installed my replacement exhaust manifold (passenger side) and my mac o/r h-pipe and mac catback. I was surprised how good it sounded at idle compared to my previous set-up (Jones Full Boar muffler welded in). But... it sounds absolutely horrible past 3k rpm! Would installing a couple high-flow cats help to keep the rasp down, or is there any way to lessen it, or will it lessen as my mufflers are broken in?
On a side note, the passenger side manifold did not fix my exhaust leak. The previous manifold was cracked, but I still have a leak coming from somewhere on that side. I plan on seafoaming it when I can get a couple friends to keep an eye on different parts of the exhaust to look for sources of leaks, but does anyone have any ideas where the leak could be coming from? I'm thinking manifold to midpipe or egr (i couldn't tighten it more than finger tight + a little).
Thanks.
Old April 18th, 2008, 01:39 PM   #2
MM's official Chevy guy
2002 Mustang V6
whitemustang02 will become famous soon enoughwhitemustang02 will become famous soon enough
Send a message via AIM to whitemustang02 Send a message via Yahoo to whitemustang02
yes cat's will help the sound
but it still woun't sound all that good on the top end. mine starts to sound bad about 4500
"Speak softly and carry a big stick" - Theodore Roosevelt
"Any idiot can make a V8 fast, it takes a real idiot to make a fast V6".
'02 Mustang N/A 4.3 stroker away for winter
'72 Chevelle project car 454 coming
'93 Bronco EFI 351W DD
Old April 18th, 2008, 01:40 PM   #3
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
was the header gasket changed? Check the collector too. I fyou get HF cats, yes it will take the rasp away.
Old April 18th, 2008, 01:40 PM   #4
94v6blkndred's Avatar
02 Turboed Saleen Clone
faster than my v6
94v6blkndred will become famous soon enough
Send a message via Skype™ to 94v6blkndred
high flow cats should take some rasp out...i didnt think H pipes were supposed to be too raspy as is...as for the leak...im not sure....seaforming will definately help ya there...sucks you replaced the manifold and still got a leak!
Old April 18th, 2008, 01:42 PM   #5
shadow5403's Avatar
h-pipe arent raspy....but its the fact that he has no cats with stock manifolds.
Old April 18th, 2008, 01:46 PM   #6
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
mac is raspy either way!
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old April 18th, 2008, 01:57 PM   #7
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
cats will help if your desperate weld in a resonator
NCMM #9
Old April 18th, 2008, 02:36 PM   #8
rob3980's Avatar
2004 Mustang 3.9L
rob3980 is on a distinguished road
I thought the same thing I just installed Mac Lt headers Mac o/r H-pipe with Magnaflow exhaust and its sounds good till you hit 3000rpms then it def sound like a ricer!
Old April 18th, 2008, 02:40 PM   #9
MM's Resident Ricer
2006 Scion tC
13.001@113
what makes you think you have an exhaust leak anyway
NCMM #9
Old April 18th, 2008, 03:29 PM   #10
Dansby's Avatar
Dansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of light
Send a message via AIM to Dansby
That was my next question. Could just be the way the exhaust sounds.
Old April 18th, 2008, 03:40 PM   #11
modded232's Avatar
Yes, I got a brand new gasket, and since it is an OE style replacement there is no 3-to-1 collector like headers have. I looked over all the welds before I put it on, and it seemed to be fine.
Started it up and had some smoke coming out of engine bay, smelled it and it was definitely exhaust. Loosened everything, and adjusted the manifold-to-midpipe joint so it was at the smallest angle I could get it, and tightened it, but there is still some smell and noise when driving (the ticking is gone, but there is still some noise, making me think it is further from the cylinder head, and closer to the manifold-midpipe joint or the egr connection). I'm no mechanic though.
Old April 18th, 2008, 03:44 PM   #12
MM's Resident Ricer
2006 Scion tC
13.001@113
well smoke is normal on new manifolds mine smoked for about a week it is oil burning off it.
Do you have a tuner?
NCMM #9
Old April 18th, 2008, 03:44 PM   #13
modded232's Avatar
I wish.
Old April 18th, 2008, 03:49 PM   #14
MM's Resident Ricer
2006 Scion tC
13.001@113
Originally Posted by modded232 View Post
I wish.
ok cause I had what sounded like an exhaust leak and it was spark knock from the tuner. get some seafoam and find the leak is your best bet
NCMM #9
Old April 18th, 2008, 05:19 PM   #15
modded232's Avatar
Will do. Thanks for the help.
Threads Similar to: exhaust question (not a common one)
Something in Common... oldernewbie The Clubhouse 3 February 21st, 2008 01:24 PM
Most Common Gear ? Montanasvt 99-04 19 February 12th, 2008 10:31 PM
Common guys Juggalo_X The Clubhouse 19 September 5th, 2007 06:38 PM
Is This Common? mustangmanic 99-04 17 July 7th, 2007 04:49 PM
Violent Shake Common? ken5_0 5.0 Mustangs 9 November 15th, 2006 02:17 AM
