torque converter drain plug?
Im going to be doing a fluish on my tranny this week, is there a separate plug to drain the torque converter? or is there only one plug to drain everything?
There is a drain plug in the convertor. There is a rubber plug on the bottom of the trans bell housing that you remove to access it. The engine has to be turned to get the plug where you can get to it.
The rest of the fluid is drained by removing the oil pan from the transmission. It will take at least 10 qts of fluid to refill the trans/torque convertor. |
#4 | |
#5 | |
The engine needs to be turned to remove the torque convertor drain plug, which is accessed through a hole in the bottom of the bell housing, after removing a rubber plug. In other words you need to turn the engine till the drain plug lines up with the access hole. |
And how would i go about turning my engine? Basically it seems that it will be easier to just have a machine suck out all the junk, rather than drain the converter.
#7 | |
It may well be easier to have it flushed by a shop. |
Threads Similar to: torque converter drain plug?
| tranny fluid drain plug? | Hunt_chevs | 5.0 Mustangs | 13 | February 26th, 2008 08:09 AM |
| coolant drain plug | Buttaz | V6 Mustangs | 2 | July 25th, 2007 01:01 PM |
| block coolant drain plug | Buttaz | V6 Mustangs | 5 | July 24th, 2007 05:34 PM |
| Drain Plug Difficulty | mystang428 | 99-04 | 2 | March 5th, 2007 08:45 PM |
| Where is the drain plug located for my coolant? | joshh58 | 96-98 | 2 | February 5th, 2007 11:53 AM |
