Caliper Piston Won't Compress - Page 3
Closed Thread
LinkBack (1) Thread Tools
Old February 13th, 2010, 06:39 PM   #41
Look Ma! My First Post!
Woolval is on a distinguished road
Success in compressing pistons!!!
I just went thru the "joy" of replacing my wife's 06 Mustang rear pads. No one here mentioned that the rear pistons need to be TURNED IN. After wasting two trips to the auto parts store and getting a useless universal tool to turn the pistons in I gave up on them and ground down an old, never used, 1 1/16" socket to where it would fit into the notches on my piston. I put this custom tool on my impact wrench and slowly turned the piston back in. Amazing how much a correct tool makes a job go easier. New pads are installed, everything back together and road test was successful.
So, I remember someone here saying they were an ASE certified mechanic. Did you mention that these pistons need to be turned to get them back in? If so, I missed it.
Hope this helps someone who might be searching for the answer on how to compress the rear brake pistons.
Val
Old February 13th, 2010, 06:57 PM   #42
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
Originally Posted by WLJohnson05 View Post
the rear calipers require the use of a tool and it has to be turned...on the front ones that works tho
Val
gonna go ahead and close this, but yes someone did say that already
SCT Mass Air Flow Sensor $200
Closed Thread
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/67173-caliper-piston-wont-compress.html
Caliper Piston Won't Compress This thread Refback October 12th, 2010 01:17 PM
Threads Similar to: Caliper Piston Won't Compress
Piston Stop 68 dlxcoupe 96-98 6 March 26th, 2008 05:17 PM
Effing CALIPER..... Help? 2much4u 99-04 9 December 30th, 2007 02:23 PM
Piston sizes? MySallyMI 99-04 9 May 22nd, 2007 06:10 PM
caliper pistons mikethetigerrr V6 Mustangs 6 January 22nd, 2007 01:17 AM
PISTON ? 89GTCONV 5.0 Mustangs 1 June 14th, 2006 09:44 PM
