Caliper Piston Won't Compress
Closed Thread
LinkBack (1) Thread Tools
Old April 20th, 2008, 08:00 PM   1 links from elsewhere to this Post. Click to view. #1
jabrennan's Avatar
jabrennan is on a distinguished road
I'm in the process of installing new rear rotors and brake pads on my 01 mustang 3.8. I have the new rotor on one side and the pads in, but I cannot get the caliper piston to compress so that I can finish this side. I have removed the parking brake cable from the spring housing it was seated in. I purchased a brake caliper tool also and it hasn't helped. I cannot get the piston to budge at all. I'm applying pressure and turning clockwise. If I've read correctly, the piston should screw in fairly easily. Is there something that I'm missing? Or has my caliper seized somehow? I haven't noticed any problems braking on the side that I'm working on right now.
2001 Mustang V6 Coupe
Visual: Mach1 Chin Spoiler, shorty antenna, side window louvres, bullitt interior, custom painted interior, white gauge face, bullitt rims
Performance: CAI, True Dual Exhaust w/flowmaster super 40s and fabbed h-pipe
Old April 20th, 2008, 08:22 PM   #2
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
what are u using to turn the tool? mine was kinda hard to turn too so i got an extension and it was much easier
SCT Mass Air Flow Sensor $200
Old April 20th, 2008, 08:32 PM   #3
burin_rubber's Avatar
1998 Mustang V6
burin_rubber is on a distinguished road
Send a message via AIM to burin_rubber
i use a large c-clamp
Old April 20th, 2008, 08:35 PM   #4
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
the rear calipers require the use of a tool and it has to be turned...on the front ones that works tho
Old April 20th, 2008, 08:37 PM   #5
jabrennan's Avatar
i'm using a caliper piston tool...it attaches to a ratchet so you can turn the piston back in...problem is it won't move...i hadn't noticed any braking problems so i'm assuming that i'm just a retard and not that the caliper has seized...my question is is there anything that i forgot to do that would be preventing the piston from turning?
Old April 20th, 2008, 08:47 PM   #6
1998 Mustang V6
did u open the bleeder valve
Old April 20th, 2008, 08:50 PM   #7
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
when i did mine it was tough too and even more tough on the passenger side...so like i side i used an extension to give me a lil more torque and then it finally started turning and once it starts turning its pretty easy
Old April 20th, 2008, 09:34 PM   #8
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
well....
idk if im right but the front ones are used for braking the rear ones are just the emergency brakes or maybe the the braking is distributed like 90% front & 10% back? or my car is retarded. Cause i never needed to replace the rear pads while the front ones have been replaced 1 time (since owning the car 8-10 months)
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old April 20th, 2008, 09:51 PM   #9
jabrennan's Avatar
No do I need to open this?
Old April 20th, 2008, 09:54 PM   #10
jabrennan's Avatar
Originally Posted by El_Cangri View Post
well....
my front pads are fine...my drivers side rear outer pad wore all the way down and scraped up the rotor a little...drivers side rear inner pad still had some life left in it however...rear passenger were both wearing about the same but need replaced also...if the braking is 90% front then maybe my calipers have seized somehow...i'm still betting i'm just retarded though
Old April 20th, 2008, 10:23 PM   #11
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
dude i had the same exact problem....and me and my dad figured out that the rear pistons have to be turned to go in and if they dont go in all the way when you turn them you need to get a new caliper....me and my dad tried everything to get the piston to go in but it was a bout 3/4in away from going on the rotor...so if you absolutely can not get it to go on you need to get a new caliper
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old April 20th, 2008, 11:22 PM   #12
jabrennan's Avatar
I'm thinking that might be the problem. The only thing that makes me second guess is that I am having the exact same issue with both the rear driver and passenger side caliper. Neither one of them will budge even with the caliper tool. I'm thinking that I'm somehow missing something simple, or both calipers have failed.
Old April 20th, 2008, 11:51 PM   #13
2009 v6 Mustang
with me it was just the passenger side...the driver side was tough but it compressed...but i did have to buy a new caliper for the passenger side
Old April 21st, 2008, 12:26 AM   #14
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
i really think u just arent turning hard enough...mine didnt want to turn at first either...i remember sittin there thinking wtf why is this not working and then i said fuck it ima turn this bitch and i put some muscle behind it and they started turning and it worked.
Old April 21st, 2008, 12:28 AM   #15
2000 Mustang V6
use some muscle then lol
Old April 21st, 2008, 05:15 AM   #16
'02SilverBullet's Avatar
'02SilverBullet is an unknown quantity at this point
No! No! NO!
I had the same prob when I done my brakes too. The other guy was kinda right when he asked about the bleeder valve... or all the way right hell....
But what I ended up doing was taking the cap off the master cylinder (where ya put the brake fluid under the hood). Doing that frees up pressure on the lines so while your compressing the calliper the brake fluid can go back to the resevoir (sp). Thats the only reason your calliper wont compress. you got fruid that pushed it out that far when it gets compressed that fuid has to go somewhere.
Just take the cap off the brake fuild thing under the hood and if your worried it may overflow just stuff some rags around it... go compress the callipers and re-assemble everything and put your cap back on.
Bet cha a dollar that works LOL!
Old April 21st, 2008, 05:29 AM   #17
DanTheMan's Avatar
1995 Civic EX
Soon to see a Garrett 60 trim
DanTheMan will become famous soon enough
^ I had to do that when I did my front brakes, that's probably your problem
My honda
Old April 21st, 2008, 09:05 AM   #18
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
dont just take the cap off....
your piston is zeezed seezed w/e its spelled
if that were the case that all you had to do was take off the cap dont you think everytime you took it off you'd get air in the lines and lose pressure....
so thats bs
[SIGPIC][/SIGPIC]
Acmillr loves me
Old April 21st, 2008, 01:04 PM   #19
Refer back to my first post... the last sentence....
Bet cha a dollar it works!
Mods Include......
BBK CAI
MM Caster Camber Plates
Baer Decalla Drilled and Sloted Rotors
w/ painted callipers
Hypercoated 18x9 FR500 Rims
Eibach Pro Kit Lowering Springs
More to come.....!
Old April 21st, 2008, 02:45 PM   #20
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
so thats bs
+1 then u get air in the lines and have to beeld everything...
Closed Thread
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/67173-caliper-piston-wont-compress.html
Caliper Piston Won't Compress This thread Refback October 12th, 2010 01:17 PM
Threads Similar to: Caliper Piston Won't Compress
Piston Stop 68 dlxcoupe 96-98 6 March 26th, 2008 05:17 PM
Effing CALIPER..... Help? 2much4u 99-04 9 December 30th, 2007 02:23 PM
Piston sizes? MySallyMI 99-04 9 May 22nd, 2007 06:10 PM
caliper pistons mikethetigerrr V6 Mustangs 6 January 22nd, 2007 01:17 AM
PISTON ? 89GTCONV 5.0 Mustangs 1 June 14th, 2006 09:44 PM
