Discussing 2001 Accelerates Rough, Makes A Popping Noise in the V6 Mustangs Forum. My 2001 v6 sputters and makes a clattering noise when I try to accelerate. And ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2001 Accelerates Rough, Makes A Popping NoiseWhen I accel really slowly, it doesn't seem to do it as severly. I did some research myself and figured it could be the fuel filter, I changed it (it was really dirty btw) but nothing has changed. Could it be anything to do with my transmission or clutch? Or is my engine just still dirty from the bad fuel filter? |
2004 mustang 40th annv.
exhuast maybe? have it checked for leaks? sounds like a back pressure thing
2000 Mustang V6
unknown @390
you might have an exhaust leak...(crack somewhere in your exhaust)
coils ? how many miles you got on it ?
66k miles. it seems that it only does it when the RMPs are low, like under 1.5k and accelerating. Once I'm up closer to 2k it run fine.
im gonna have to say exaust leak... when i got duals put on mine the right side pipe right after the muffler was cracked open a bit and it did the same thing your describing.. i never found out what it was till i had it up on the lift changing my oil a couple days after.. i just took it back in and they fixed it up with no problems.
Chris |
Thanks a lot, must be those stupid speed bumps. About how much do you think this is gonna cost to get fixed?
2000 Mustang V6
unknown @390
if you can weld...free. if not my dad knew someone that did mine for nothing...it isnt a hard job
but i dont think its an exhaust leak if it stops after 2k rpms. i have 3 exhaust leaks, an exhaust manifold leak and 2 exhaust leaks, the sound is noticable when ever you hit the gas a little |
I'll have to make a trip to my uncle's shop and get it up on a lift to see if i can find a leak. If not, I'll bring it to my mechanic.
ive got 1 rigth after my muffler and it stopped after 2k?? and all i did since it was a small leak was buy 1 of those pipe repairs from advance auto parts and patch it up.. after you put that last coat of glue they give you it became hard and the noise stopped. problem solved but then again lol i knew what my problem was. good luck!
Chris |
1999 Ford Mustang V6
could be spark knock?
...even fire and single cammin |
Threads Similar to: 2001 Accelerates Rough, Makes A Popping Noise
| Popping noise in the front lower area? | lighterzen | 94-95 | 3 | October 18th, 2007 12:41 AM |
| Popping noise in Neutral | Dallas01GT | 99-04 | 1 | August 17th, 2007 03:34 PM |
| Popping noise? | BrightWhite98GT | 96-98 | 4 | July 22nd, 2007 11:46 PM |
| Fuel Gauge No Worky and Odd Popping Noise | armadillon | 5.0 Mustangs | 4 | July 12th, 2007 05:00 PM |
| Popping noise | weems | 5.0 Mustangs | 1 | August 31st, 2006 11:44 AM |
