Miss fire
Old April 21st, 2008, 11:22 AM   #1
2001 Mustang V6
AnFking6908 is on a distinguished road
Send a message via Skype™ to AnFking6908
Miss fire
i have a 01 v6....the other day i was running my car down the road wen it started to miss so bad that the check engine light was blinking... i replace the plugs, put on new MSD 8.5MM wires and a new fuel filter... it after this was replaced and exhaust leak came up on the driver side of the exhaust manifold... so i took it to a shop n they said the diagnostic said it had a miss on cylenders 1-6 so they told me to replace the coil pack... if that dont work then replace the modulator under the coil pack n if that still dont work replace the crank censor... its a steady miss but the car runs a hell of alot faster now that i replaced the plugs wires n filter... wat should i fix next??? n is their any performance coils i can buy?
Old April 21st, 2008, 11:28 AM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
blinking light = random misfire.
What plugs are you using?
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old April 21st, 2008, 12:41 PM   #3
stephen has a spectacular aura aboutstephen has a spectacular aura about
A lot of things could be wrong, but replacing the coil and crank angle sensor is reasonable.
Old April 21st, 2008, 01:17 PM   #4
Toph6888's Avatar
2000 Mustang V6
Toph6888 is on a distinguished road
Send a message via AIM to Toph6888
screamin deamon coilpack is about the only one u have to choose from lol
Old April 21st, 2008, 02:50 PM   #5
2001 Mustang V6
is that screamin deamon coil pack worth spending $30 more to get it over the stock??
Old April 21st, 2008, 03:25 PM   #6
You might get other opinions, but I doubt it's worth it. There is plenty of voltage to fire the plugs with a stock coil.
Old April 21st, 2008, 03:27 PM   #7
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
get the code pulled if it is 2 parallel cylinders missing replace that coil
NCMM #9
Old April 21st, 2008, 04:47 PM   #8
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
could be a fuel injector too. Seafoam that bad boy
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old April 21st, 2008, 05:46 PM   #9
Are you saying cylinders 1 and 6 have a misfire or all 6 cylinders (1-6) have a misfire? The pairs per coil, unless I'm mistaken, are 1 and 5, 2 and 6, and 4 and 3. Thus, it seems unlikely the coil is the problem, since I would expect only one of the three coil sections to fail.
I would think it could be narrowed down by determining which cylinders have spark. If one of the pairs above is bad it's the coil. If they are all weak, I would expect something other than the coil, perhaps the crank angle sensor. If the spark is good on all cylinders, then it may be fuel related, such as a clogged injector as someone mentioned.
Is it possible you got some water in the gas?
Old April 21st, 2008, 05:54 PM   #10
2001 Mustang V6
no they said it was 1 and 6 that were missing
Old April 21st, 2008, 06:18 PM   #11
That seems unlikely to be the coil, since 1 and 6 are next to each other in the firing order, and thus come from different sections of the coil pack.
I would try an inductive pickup timing light on each plug wire in turn and see if any fails to trigger the light.
Threads Similar to: Miss fire
What I miss? G.T. Rags The Clubhouse 16 April 20th, 2008 07:21 PM
Miss-fire. RAGEman 99-04 6 February 17th, 2008 11:26 PM
Trying to get my 347 to fire, Help please! problemCOBRA94 5.0 Mustangs 56 January 26th, 2008 08:31 AM
Fire In A 66 460brevill Classic Mustangs 10 December 3rd, 2007 11:46 PM
so what did i miss... Onemanzu V6 Mustangs 15 December 28th, 2006 12:14 AM
