#21 | |
2004 Mustang V6
you know what... i think ur right. b/c when i got into my 2nd car accident i had to slam my brakes like the hardest i have ever slammed them in my life. so that could be it. i changed the front ones cuz they were messed up, but can the brakes mess up that bad in the rear b/c i only thought like 40% of braking was done from the rear brakes and the front ones are what take the biggest load.
2004 Mustang 3.9L V6 with K&N intake, Dual Flowmaster Super 40s, Motoblue 42% Pulley, GT rear sway bar, drilled and slotted rotors, SCT tuner, Black FR500's 17 by 10.5 and 17 by 9, 4.10 motive gears and FRPP T-Lock. |
#22 |
2004 Mustang V6
and by the way is it possible to turn drilled and slotted rotors??? cuz paying another 150 bucks is gonna suck.
#23 | |
MM's Database Error
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
#24 | ||
1998 Mustang V6 5 spd.
#25 |
MM's Database Error
k..it wont be able to be checked out till i get home on the 10th...ugh..when i did my brakes the only thing i didnt replace is the front two rotors bc they looked like they were ok...guess ima have to get two more...might order some...any recommendations?
#26 |
2004 Mustang V6
dang this sucks. i guess i have no choice but to change the rotors. do u think i should change the pads as well? the pads are still thick as hell and they are practically new, but if the rotor is warped then the pads are prob off then too huh?
#27 |
MM's Database Error
if the pads arent messed up im sure they would just take a lil bit and create a new wear pattern
#28 |
2004 Mustang V6
i use these rotors and love them. just make u get the ones for ur year and u need front ones i believe u said. just check that site out .
MUSTANG 03-04 Base & GT Rear Drill Slot Brake Rotors + Pads: RDS1426 - 121.61042 - 104.06270 R1 Concepts Inc. - Discount Performance Brake Rotors
#29 |
2004 Mustang V6
alright i just called that place up there to see if i had warrenty or whatever on em and the guy said its not ur rotors. he said if it was ur rotors it would vibrate and do other stuff. he said its the pads. he said check and see if there is like a small piece of metal hanging off the pad or something or try and putting new brake compound stuff on the contact points. he said if that dont work to call him back. so ima try taking them apart again and putting new compound stuff on and maybe lightly brush the surface of the pads. ill prob do this either later today or tomorrow and tell u how it goes.
#30 | |
MM's Database Error
#31 |
2004 Mustang V6
ok i just got done cleaning everything again with brake cleaner and reapplying brake compound on the contact points and anti seize on the caliper bolts. its still doing the same damn thing. so i guess there is nothing left but to replace the pads and rotors. ima call the place i got it from and see if they will give me a discount or something since my brakes and rotors are barely 3 months old.
#32 |
Bring it to the guy & ask him to check it over, he should be a professional & not leave you with a problem!
#33 |
check your ebrake. i drove probly 10 miles in my lebaron scratching my head because i kept hearing this whistleing/squeaking/killmyself noise, then i look down and my ebrake was engaged. That says two things: 1. I am a retard. 2. My ebrake is shit.
#34 | |
MM's Database Error
#35 |
2004 Mustang V6
the dude installed them right cuz i took em off and put them back on about three times and its still doing it. i think its just a combo of both the pads and rotors. since i slammed the brakes that one time it probably messed up something. ima prob change em so ill let u kno whenever i figure it out.
#36 |
2004 Mustang V6
ok i figured out what was wrong. the dumbass who installed my brakes forgot to put those metal clips that go on the top and bottom of the pads on the rear. he didnt put them on the rear pad so thats why it was squeaking. i called him and told him and he got me new ones. i ended up changing the pads and rotors on all four corners and no more noise.
Threads Similar to: squeaking rear wheel
| Are posted hp gains at the flywheel or rear wheel? | AggieStang | General Tech | 5 | October 19th, 2007 12:55 PM |
| Rear wheel noise ? | Hudstang | 96-98 | 3 | September 1st, 2007 08:36 PM |
| buzzing from rear wheel | tjames | V6 Mustangs | 5 | July 26th, 2007 07:00 PM |
| 17x10.5 rear wheel on the back of a 87-93 GT????? | 5.0newbee | 5.0 Mustangs | 8 | January 15th, 2007 03:41 AM |
