squeaking rear wheel
Old April 21st, 2008, 08:46 PM   #1
stang300a's Avatar
2004 Mustang V6
stang300a is on a distinguished road
ok so for a week my rear driver wheel has been squeaking when i drive and it started getting louder and louder, but when i barely touch the brakes it stops and when i release the brake it starts again. so i figured it was the brakes. i took the wheel off, pads off, sprayed everything with brake cleaner and put it back together and its still doing it. im about to kill myself cuz its so annoying. how do i fix this????
2004 Mustang 3.9L V6 with K&N intake, Dual Flowmaster Super 40s, Motoblue 42% Pulley, GT rear sway bar, drilled and slotted rotors, SCT tuner, Black FR500's 17 by 10.5 and 17 by 9, 4.10 motive gears and FRPP T-Lock.
Old April 21st, 2008, 08:49 PM   #2
stang300a's Avatar
2004 Mustang V6
oh yea forgot to mention the brakes rotors and calipers are all brand new and only two months old. no i didnt install them a shop did.
Old April 21st, 2008, 09:13 PM   #3
Senor Pointy Boots
atlacatl213's Avatar
2003 Mustang V6
Needs Track Time
atlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to behold
Send a message via AIM to atlacatl213
hmm my best guess is probably that you've assembled it too tightly. That and sometimes the brand of the pads used aren't that great. I'm not too sure about it though it sounds unusual to me.
Old April 21st, 2008, 09:30 PM   #4
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
mines like that too but i think its the front driver side tho...
SCT Mass Air Flow Sensor $200
Old April 21st, 2008, 09:34 PM   #5
moond0ggie's Avatar
1998 Mustang V6 5 spd.
moond0ggie is on a distinguished road
They're supposed to put the anti squeak goo on the back side of the pads where they make contact with the caliper & piston.
http://www.moddedmustangs.com/forums/signaturepics/sigpic13601_6.gif
Old April 21st, 2008, 09:35 PM   #6
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
Originally Posted by moond0ggie View Post
They're supposed to put the anti squeak goo on the back side of the pads where they make contact with the caliper.
he said they did. and i did that with mine when i did it too...
Old April 21st, 2008, 09:40 PM   #7
moond0ggie's Avatar
The caliper should have some light grease on the two pins it floats on also.
Old April 21st, 2008, 09:41 PM   #8
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
greased pins also...
Old April 21st, 2008, 09:52 PM   #9
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
walk beside it as someone drives and see if you can pinpoint the location
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old April 21st, 2008, 10:17 PM   #10
stang300a's Avatar
2004 Mustang V6
what ima do this weekend is jack up the rear end and spins the wheels and see where the noise is coming from and then take the wheel off and spin and then the pads off and spin it and that way ill pin point what it is. i just want to fix this before i get the gears and t lock installed.
Old April 21st, 2008, 10:18 PM   #11
stang300a's Avatar
2004 Mustang V6
any other suggestions and yes i checked and there was grease on contact points and anti seize on bolts for caliper.
Old April 21st, 2008, 10:28 PM   #12
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
definitely lemme know if u figure this out cuz i have no clue either
Old April 21st, 2008, 11:43 PM   #13
stang300a's Avatar
2004 Mustang V6
yea ill def post what it is if i figure it out, but ill tell u right now ima figure it out cuz everytime i drive the car i get frustrated b/c of that noise and then get in a pissy mood all day. i just need to wait for this weekend so i can go home and use jack stands to get the rear end up.
Old April 22nd, 2008, 12:34 AM   #14
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
yea im the same...i drive it and im like fuck this piece of shit why are u doing that...its so random too cuz it didnt do this a while back....but i also noticed my wheel getting pretty hot sometimes like things are gettin extremely hot, idk if that has anything to do with the squeek tho
Old April 22nd, 2008, 01:05 AM   #15
stang300a's Avatar
2004 Mustang V6
hmmm... i havent noticed my wheel getting hot but ill check tomorrow
Old April 22nd, 2008, 08:20 AM   #16
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
if you had a shop put them on, and they are making noise....and they werent before you took it to the shop.....why not take it back to the shop? You paid for a service that they are responsible for.
Old April 22nd, 2008, 09:43 AM   #17
97fordsixer's Avatar
97 single port w/bolt ons
n/a
97fordsixer will become famous soon enough
I had this issue and had to replace the cheap rotor i put on with a new one. it had too much runout... any one no how that happens with a new one..let me know
Old April 22nd, 2008, 05:04 PM   #18
stang300a's Avatar
2004 Mustang V6
ok the thing is that i got in a car accident last december and they had to replace my entire rear end and i had them put the same rotors and pads i had before which are drilled and slotted. well anyways, i know its not b/c of the brand or anything like that cuz i had the other ones on for over a year and they were fine. plus, it didnt start doing it until like 2-3 months after i had been driving it, so if i take it to the shop again they will prob say some bullshit like oh thats normal wear and tear. i never let anyone do work on my car anyways. i do it all my self but b/c it was done through the insurance i didnt have much of a choice.
Old April 22nd, 2008, 05:08 PM   #19
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
yea i hate taking my car to any shop...it bugs me...i hate it...but see we both have the problem and i did my own and u took urs to a shop...ur rotors are new and mine is the one that was on it, but it looks fine to me...
Old April 22nd, 2008, 05:11 PM   #20
moond0ggie's Avatar
If you do a lot of heavy braking, it will overheat the rotor & warp a little out of round.
They may need to be turned-trued.
Threads Similar to: squeaking rear wheel
Are posted hp gains at the flywheel or rear wheel? AggieStang General Tech 5 October 19th, 2007 12:55 PM
Rear wheel noise ? Hudstang 96-98 3 September 1st, 2007 08:36 PM
buzzing from rear wheel tjames V6 Mustangs 5 July 26th, 2007 07:00 PM
17x10.5 rear wheel on the back of a 87-93 GT????? 5.0newbee 5.0 Mustangs 8 January 15th, 2007 03:41 AM
