2004 Mustang 3.9L
Eaton M112
If I was to get a Eaton for my 2004 V6 waht all would i need with it to make it run correctly?
muneris pro ego
a lot. it definitely wont be just a bolt on thing. you will need the adapter plate from SSMS and lots of other things to make it fit. i believe there is a guy named mysteed that sells a kit of everything you need to install a m112 besides the m112 itself and the adapter plate from SSMS... i dont know what forum mysteed is a part of either.. google it
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
2004 Mustang 3.9L
It comes with (off of a 2004 Cobra)
1.) M112 w/ stock pulley 2.) 39lbs injectors 3.) 90mm mass air sensor 4.) Heat exchanger (intercooler) so besides the adapter plate what else would i be lookin at ? |
muneris pro ego
i dont know what else.. look up mysteed on google and see if you can find a kit from him. or just google m112 v6 mustang kit. no one on MM has done the swap so i have no clue what all is needed
2004 Mustang 3.9L
i found him on gotstang thanks man
[8MINUS2]
Their is a pretty long list of parts, nuts, bolts, hoses, idlers, etc.
About 24-2800$ worth of stuff.
adapter plate
m112 s/c idle pulleys longer belt of course MAF injectors fuel pump tune vacuum hoses and other misc parts
#8 | |
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
M112 Supercharger plentium throttle body 39# fuel injectors 90 mm maf with sensor boost bypass Stock supercharger pulley throttle/ cruise control bracket air intake tube throttle position sensor m112 supercharger gasket/ rtv sealent plentium gasket throttle body gasket fuel injector o rings v6 upper intake gasket m112 intake adapter pcv delete m112-cobra egr delete iat and wiring 310lph fuel pump new spark plugs long belt i think 103 inches air filter with air box egr delete for v6 engine and some bolts, most can come from your engine/ parts that you take off! yours also going to have to extend your IAT sensor shave off intercolor lip make the idler pulley 'custom' radiator hose and reloacte your IAC ! im pretty sure thats everything! hope this helps someone! |
MM's Database Error
his thread about it is on 3.8mustang.com
M112 kit *Update: post 1753* 4/15/08 - 3.8 Mustang Message Board
Threads Similar to: Eaton M112
| m112 eaton | emgjsdk1 | V6 Mustangs | 13 | February 16th, 2008 10:16 PM |
| I know the m112 eaton is a sore subject but... | f0rdguy | 99-04 | 16 | December 27th, 2007 12:35 AM |
| m90 or m112??? | 94pacecarSVT | V6 Mustangs | 17 | March 27th, 2007 01:13 PM |
| m112 | mmvi | V6 Mustangs | 34 | March 5th, 2007 04:38 PM |
| Will An Eaton M112 Supercharger Fit On My GT? | phisherize | 99-04 | 6 | November 16th, 2006 06:54 AM |
