#21 |
This link should answer your question.
Catalytic Converter Removal - Beat the Law - Import Tuner Magazine |
#22 |
MM's Resident Ricer
2006 Scion tC
13.001@113
Unless you have a sniffer there is no problem with removing them if you can get the CEL removed. My car even passed the sniffer with no cats
#23 | |
MM's official Chevy guy
Ticket-Me-Yellow why don't you go with a cated h pipe, that way you don't have to worry about emissions, and it will make the car sound better, preform a little better (due to more back Pressure creating more low end TQ), and be better for the Environment.
![]() "Speak softly and carry a big stick" - Theodore Roosevelt "Any idiot can make a V8 fast, it takes a real idiot to make a fast V6". ![]() '02 Mustang N/A 4.3 stroker away for winter '72 Chevelle project car 454 coming '93 Bronco EFI 351W DD |
#24 |
It is illegal to remove a working cat, but alot of state dont do sniffer tests so that how you get away with it.
#25 |
Actually, it's a violation of federal law (the clean air act) to remove a catalytic converter.
Emissions Control Tips - Catalytic Converter Tips |
#26 |
we dont have inspections in oklahoma
![]() JAKE'S PIITB CREW MEMBER#4 |
#27 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
#28 |
The following is my understanding of the federal law.
It specifies conditions for replacing a catalytic converter. I don't think there is any situation where a converter can be legally removed and not replaced. Catalytic Converter Laws If you live in a state without inspections you can probably get away with it, but it would then not be possible to register the vehicle in a state that requires an inspection. |
#29 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
#30 | |
OK. Then it may be OK to remove the converter if you can still pass the state requirements and no shop helps you with it.
I didn't know that.
#31 |
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah and if the shop does it they are at fault if your car fails not you thats the reason any shop that does inspections wont touch a cat or a header
#32 |
Was doing some research and came across this post. First a thought, then a question.
My old car, a '92 Lumina with 200K+ miles, passed an emissions test without a cat... except they checked underneath, saw no cat, then failed me, forcing me to replace the cat - even though I had passed without it. That whole federal law/tampering business... So, even if you pass the sniffer, you can still fail, depending on the testing center you go to (and how visible the cats are in the first place). That leads me to my question... I'm beginning to consider mods to my 'stang, and most things that I've read are telling me one of the first things to do is to replace my exhaust system... it looks like it would not be a big deal at all to go dual exhaust ('04 stock v6), but I'm unsure of what my options are and how far I can upgrade it while still passing the Hamilton County (TN) emissions test. Should I consult: a) a mechanic b) the testing center themselves c) a helpful link someone will feel free to post that will answer all my questions about emissions testing in Tennessee ![]() Thanks! |
#33 |
2004 Mustang V6
consult the testing center. If you need to visually have cats, just gut them or go high flow.
#34 |
yeah most emmissions testing shops have to do a visual..they will fail you if they dont see them ..
01 v6 true duals with 40 series flows and custom h pipe cold air intake http://www.myspace.com/xxarsonfreakxx (PERSONAL) http://www.myspace.com/vicious_racing (THE STANG FAMILY)
Threads Similar to: Emissions Question
| VA Emissions Question | Cricket | The Clubhouse | 16 | April 22nd, 2008 07:48 PM |
| emissions question for exhaust | mexlatino | 96-98 | 2 | February 18th, 2008 02:56 PM |
| 1990 Emissions Question | motorhead6776 | 5.0 Mustangs | 7 | January 11th, 2008 10:38 AM |
| emissions in NY? | KenDogg | General Tech | 2 | January 2nd, 2008 08:21 PM |
| Emissions stuff question | cobralini | 5.0 Mustangs | 4 | June 1st, 2006 10:52 PM |
