¡ʇsnq ɹo uʍop ǝpısdn
Blown Gasket... I Think
Okay so i have an interesting story... but im goning to start with the problem. my car(97 v6 5 speed) is leaking oil. and im not sure why or where exactley it is coming from but it is leaking it something feirce.
The cause of this is rather odd... I blew the heater core hose in my car right behind the distributor cap, and limped the car home, which was only two small blocks. my car then sat for a week as i fixed the problem and now it is up and running again. As soon as i started driving it agian i noticed that oil leaks were showing up in my drive way. Any ideas at all? Also where could i get the parts to fix this problem? |
my 94 blew the head gasket, although im far from an expert, wouldnt it have flooded the cylinder with antifreeze, especially after a week of sitting? did it start alright after u fixed it?
that is more likely, expecially with the oil leak
![]() lol much cheeper and easier |
if you get Hayes manual at like autozone or w/e, it gives step by step real easy instruction. i dont remember well enough to type it to ya, lol, but i dont remember that being very difficult, now getting to the covers was tricky and all the stuff you have to pull off to get there, but really not tooo bad
aight ima re open this... i still havne't fixed the gasket but thats okay...
is it possible to have a small hole in a gasket... cuz when ever i drive i still can smell burning coolant... even tho i have washed out the engine bay many times... and i think that coolant and oil are leaking and miking in to the cylinder... so just wondering what yall think
#8 | |
well the big thing im seeing right now is the smell of burning coolant... which isn't a bad smell but mos def a bad sign... any other suggestions ideas...
thanks btw
2003 Mustang GT
definatly check the bottom of the timing cover ford v6's had a lot of problems with proper sealing on the timing cover
also you can get some oil dye from an auto parts store and check it after 500 miles
70mm t/b, plenum, cast intake manifold, full magnaflow exhaust, JLT cai, FRPP c springs, anti roll kit, steeda upper control arms, custom tune, subframe connectors, HID headlights, mach 1 chin spoiler |
if you got a blown head gasket you will have white smoke coming out of the tail pipe. to find the oil leak follow it up from the bottom where it is dripping until you find the highest point. hope it is the valve cover for your sake lol
.... that just the thing it isn't giving off water and its not putting out white smoke so i don't know what it is... im gonna try the follow the leak thing... thanks for that
1999 Ford Mustang V6
change the oil and see if you have coolant in it, should come out first, but if it is a bad leak it will be milky looking. valve cover leaking is common, so is rear main, but as advised would browse the haynes manual or look here for a general overview first to see what you are getting into and what parts you will need, can get all the gaskets and fluids at your local autozone or advanceautoparts. is your coolant level getting low?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Is your car overheating by chance? You wont neccesarily see white smoke with a blown head gasket. i know this because i had a blown head gasket and their was no visible white smoke out the tailpipe. Engine overheated every time the car ran more then about 5 mins and then coolant kept disapearing and spilling into the overflow tank.
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
Threads Similar to: Blown Gasket... I Think
| =( blown head gasket | itschristorres8 | V6 Mustangs | 17 | October 23rd, 2007 11:14 AM |
| blown head gasket | 5.0pwr | 96-98 | 2 | September 17th, 2007 11:57 PM |
| blown head gasket.......new heads? | sniperrider | 5.0 Mustangs | 18 | April 25th, 2007 11:10 PM |
| blown head gasket, or cracked heads? | Philly | V6 Mustangs | 20 | March 10th, 2007 10:21 AM |
| Blown Head Gasket | Lax89 | 5.0 Mustangs | 10 | February 17th, 2007 08:01 AM |
