7.5 rear end issue
Old April 22nd, 2008, 02:38 PM   #1
2002 V6/1967 Mustang
JasonMarshall is on a distinguished road
7.5 rear end issue
Ok, so I was going to upgrade to the 373 gear set and T loc in my 2002 v6, but my rear end decided to shred the left hand carrier bearing. Is this a common problem with 7.5's? I would hate to think that I have too much torque with just cold air, shorty headers and flowmasters on it. There's no way thats it is it?
2002 V6 Mustang/ 5 Spd, cold air, flowmaster exhaust, Hedman Headers
1991 LX 5.0 Convertible, Flowmaster 40's
1991 LX 5.0 Hatch, offroad h pipe, Flowmaster 40's 3.77's with a locker
Old April 22nd, 2008, 02:45 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
Is this after the install? Did you put friction modifier in the diff?
NCMM #9
Old April 22nd, 2008, 02:46 PM   #3
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
shred the bearing? theres the case bearing on the actual open carrier case. then you've got axel bearings
[SIGPIC][/SIGPIC]
Acmillr loves me
Old April 22nd, 2008, 02:50 PM   #4
I have been having issue's with the stock rear end and really figured it was the gears, no, actually HOPING it was the gears so I could replace them. I had to take it in to the shop because I have no clue when it comes to rear ends. They just called and said the left Carrier bearing was shredded. Thats about all I know at this point, but I was talking to another mustang guy and he said that it sounds like a case of too much torque. I jut don't see how thats possible.
Old April 22nd, 2008, 02:51 PM   #5
MM's Resident Ricer
2006 Scion tC
13.001@113
was this before you installed the gears and t-lok?
NCMM #9
Old April 22nd, 2008, 02:53 PM   #6
Yes, this is on the stock rear end. As I said, I wanted the issue to be the gears so I could upgrade. Sorry if that was not clear.
Old April 22nd, 2008, 02:53 PM   #7
00 V6 & 09 GT
not from torque, could be improper bearing preload while the new t-lok and gears were installed.
you dont shread bearings from torque if they're installed correctly
[SIGPIC][/SIGPIC]
Acmillr loves me
Old April 22nd, 2008, 02:55 PM   #8
MM's Resident Ricer
2006 Scion tC
13.001@113
shreading a carrier is tuff to do. my guess would be either your fluid just wasnt lubricating it properly pr possibly and axle some how got mis aligned or bent a little and warped the bearing
NCMM #9
Old April 22nd, 2008, 02:56 PM   #9
00 V6 & 09 GT
+1 or what he said if it was before the t-lok and gear install
[SIGPIC][/SIGPIC]
Acmillr loves me
Old April 22nd, 2008, 03:23 PM   #10
So I need to make sure they double check that axle for any warps or bends. Guess I'll have to wait a bit for the 373's and T Loc. Thanks for all the help.
Old April 22nd, 2008, 03:27 PM   #11
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Carrier bearings are not alot of money. Do the the gears and traction lock while they are in there already and save yourself a crap load of money.
Never fast enough.
Old April 22nd, 2008, 03:38 PM   #12
I'm probably getting ripped off then, the place is charging me 450 to take everything out and clean all the metal chuncks and shavings out of the rear end and replace the bearing. The gear kit is another 450 so I'll have to wait. My 67 Mustang takes all my 'extra' spending money.
Old April 22nd, 2008, 06:17 PM   #13
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah go somewhere else it should be about 450-500 to disassemble the rearend, replace the carrier, and put in t-lok and gears at the same time
NCMM #9
Old April 22nd, 2008, 07:53 PM   #14
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
They are taking advantage of your situation.
Never fast enough.
Threads Similar to: 7.5 rear end issue
Cat issue FireryDriver 2005 - 2010 19 February 27th, 2008 06:37 PM
Febuary MM&FF Issue! MustangMatt96GT The Clubhouse 99 January 12th, 2008 02:28 PM
here is my issue bigbadwollfff04 Drag 35 July 5th, 2007 09:34 PM
t5 issue 342stroker 5.0 Mustangs 3 June 4th, 2007 09:41 PM
Rear defogger fuse issue neckbonekat 99-04 5 February 12th, 2007 06:54 AM
