Discussing All Help Needed, Spider Gear installation someone please in the V6 Mustangs Forum. okay, imma try to put this whole story here, diesels mustang shredded the two of ...
Old April 22nd, 2008, 06:22 PM   #1
dgt_mustang's Avatar
01 mustang
diesels mustang shredded the two of his spider gears inside the rear diff, (neutral slam), we got new spiders gears from the dealer ship and installed them,
sides went on first
top spider gear then went on
bottom wont just wont seem to slip in there,
I didnt want to replace the spider gears, at complete rear end would have been the best thing in the world but junkyard didnt have one and im the one payin for his shit right now, (HES GOING TO PAY ME BACK, I HOPE) hes a friend,
75.00 for the new spiders gears, how can i get the last one in? is there some trick to it?
LEAVE REP POINTS WHERE NEEDED!!!
2001 mustang V6
CAI,Tuner,Cobra Rims
To come:
UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, aluminum driveshaft.
Old April 22nd, 2008, 06:52 PM   #2
Resident MM Ricer
GreenFaleen's Avatar
2006 Scion tC
13.9@103/8.9@81
grab a haynes manual. Ive never done this before
Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS
Thanks To My Sponsors:
Strup Performance
Old April 22nd, 2008, 06:54 PM   #3
01 mustang
we have the haynes manual but it doesnt say how to remove or install spider gears, all it talks about is removing the axle shafts which is the only reason it even shows the rear differential.....this sucks,
2001 mustang V6
To come:
Old April 22nd, 2008, 07:09 PM   #4
2000 Mustang V6
unknown @390
no no
you have to put the side spider gears first those are the bigger ones
then the small spider gears: WHERE ITS OPEN put them on the EXACT opposite side. if its not EXACTLY across from each other the carrier pin will not slide through fully
once directly opposite on the open side turn them with the side gears so it slides in the carrier til its lines up with the carrier hole to slip the pin through
i hope you know where each shim goes and to measure the back lash.
also do not forget the c-clips
stock the rear end only has 2 shims one on each side. if your installing a new unit the stock shims are useless
www.crtperformance.webs.com
Old April 22nd, 2008, 07:10 PM   #5
01 mustang
what is the backlash?
and the shims are the small metal seal looking things right? i got new ones with the new spider gears.
2001 mustang V6
To come:
Old April 22nd, 2008, 07:12 PM   #6
2000 Mustang V6
unknown @390
the space between ring gear teeth and the pinon gear. if its not correct you'll burn up the gears or destroy them
how many shims do you have...
Old April 22nd, 2008, 07:13 PM   #7
2000 Mustang V6
unknown @390
also i hope you know that the ring gear has to be torqued to the carrier and with loctite if you took it off...
same with the main caps..they need loctite as well
Old April 22nd, 2008, 07:21 PM   #8
2000 Mustang V6
unknown @390
your going to at LEAST need
dial indicator or another way to measure your backlash. estimating by feel is no good were talking about .008-.015 of an inch backlash is whats allowed
DEFFINITLY a torque wrench
loctite
hightemp silicone
Old April 22nd, 2008, 08:10 PM   #9
01 mustang
so like more of a job then what was initially thought, imma send his car to the shop now because no matter what we seem to do that one other spider gear doesnt seem to want to go in, two shims came with the set, along with the screw that goes into the piston that shoots down between the two,
2001 mustang V6
To come:
Old April 22nd, 2008, 08:15 PM   #10
2000 Mustang V6
unknown @390
thats the pin
bot spider gears(smaller ones) must go in at the same time...its super easy if you follow what i said
Old April 23rd, 2008, 09:08 AM   #11
Originally Posted by itschristorres8 View Post
no no
I don't think they took the carrier out, so setting the backlash is not necessary. I think the gears can be replaced with the carrier installed.
To clarify what you said above, I think you are saying to put in the side gears first, then position the two smaller gears and turn the side gears to get them in mesh and to line them up to reinstall the pin.
Threads Similar to: All Help Needed, Spider Gear installation someone please
Body Kit Installation Help Needed And Spoiler Removal Help TASSY5 2005+ 2 November 16th, 2007 01:20 PM
gear installation 1BADSTANG 5.0 Mustangs 20 October 8th, 2007 12:27 PM
zippys spider is the crack spider mpboy The Clubhouse 9 October 5th, 2007 04:00 AM
Whipple Supercharger - Installation Tips Needed sechmura 2005+ 1 June 6th, 2007 08:18 AM
Gear Installation Jeff99gt 99-04 9 March 10th, 2007 12:22 AM
