2 Questions
right, so i drive a 2002 manual v6 all stock. well i bought it used from a dealership and from the first time i started it to this very day there is a clicking noise which sounds like its comming from directly infront of the firewall in the general area where the engine and tranny connect. it makes the noise everytime i start the car and the noise says until i reach around 20 mph, but was it goes away its gone. any ideas wut the problem could be?
also about a month ago it started making a deeper clicking noise that sounds like is directly behind the odometer or somewhere near the stearing colum when i apply pressure on the brakes. it only happens every now and then and it depends on how hard i press the brake. it usually occurs when i apply pressure between barly hitting the brakes and slamming on the brakes. once again any ideas? |
i know someone who had that problem, but i dont tihnk it effected there car at all
sorry imnotrealy that much help lol |
hmm, ive never heard of anything like that....
i dont understand your first question...you sed its coming from the front firewall right next to where the engine and tranny connect...thats 2 different spots... i would take it back to the dealer...i woulda taken it back the day i heard it tho....didnt you test drive it?
no i was trying to say that its either comming from in front of the firewall or in the area around where the tranny and engine connect.yea i test drove it, but i didnt notive either of the noises.
hmm, is there anyway you could get a video of the sound or a sound clip of the clicking
#6 | |
hmm, ill try. if i can itll be posted by tonight.
well unfortunatly my digital camera doesnt record sound, but i listened to the clicking more with the hood up and have determined that it is comming from somewhere around the intake manifold.
what rpm does your car sit at, at idle...
right at 1000
you most likely have an intake manifold leak.
it should be idle at 750
check the hoses aorund that area one of them is like an exhuast from the engine. its in the back on the left
ok ill try checking the hoses and if i cant fix it my dad has a friend whos a mechanic. he should be able to atleast find the problem. lol, thanx for the help
spray some carb cleaner over your intake manifold with your car on....im told that if your car surges wen u do that...uve found your leak
ok well i found one loose hose, tighten it, crank the car. clicking still there. although i have discovered that if i let the car idle for about 45 secounds it stops, and that if i just get in and the clicking is gets louder until it fades away. i read in the owners manuel that the standards need approx. 5 minutes of warm up time? maybe thats the cause of clicking, it just needs to warm up a bit. idk.
#15 | |
btw scubasteve u need to post some pics of ur car, id like to see those leds in the dark.
your car shouldnt have that noise....spray the cab cleaner with your engine on
i should be able to get some carb cleaner from like walmart right?
idk i think so...if not discount auto parts, advanced auto...etc will have it or a hardware store
alright ill prolly get some tommarow and see if i can find a leak.
#20 | |
saw something in another forum involving a 02 stang with wut sounds like the exact same problem. replys about it said it could be the smog pump. wut do u think?
Threads Similar to: 2 Questions
| New here got a few questions | JonnyB | 5.0 Mustangs | 17 | August 19th, 2010 01:39 PM |
| Few Questions | Bies08 | V6 Mustangs | 12 | August 21st, 2007 11:33 PM |
| rim questions | SilverGT04 | 99-04 | 26 | August 17th, 2007 02:54 AM |
| *a few questions* | mustang1072 | V6 Mustangs | 10 | June 29th, 2007 12:59 AM |
| Questions about new car! | Blown93Cobra | 5.0 Mustangs | 6 | June 4th, 2007 04:45 PM |
