just rebuilt car and now it wont run.... - Page 6
Old May 4th, 2008, 09:04 AM   #101
stephen has a spectacular aura aboutstephen has a spectacular aura about
Originally Posted by 99v6stang View Post
i have another cps, but the one i put in came of a working engine so i would think that would have worked. I guess we will see tomorrow when i have some time. Could i crank the engine over with no spark pulg wires attached without the timing cover on just to check compression?
You won't have oil pressure, but it's probably OK just to check compression.
You only need a few compression strokes per cylinder.
Old May 4th, 2008, 03:52 PM   #102
99v6stang's Avatar
99v6stang is on a distinguished road
Ok compression results are in... Using an Innova compression tester from fleet farm.
Cylinder 4 -- 135 Cylinder 1 -- 135
Cylinder 5 -- 165 Cylinder 2 -- 145
Cylinder 6 -- 160 Cylinder 3 -- 155
Obviously the compression is higher near the rear of the engine for some reason, is this common? So the lowest compression is over 75% of the highest compression so overall compression is good? If compression is fine, the tune is fine, and the timing is fine, THEN WHAT THE FUCK IS WRONG WITH MY CAR?????????????????????
My car ---- (m112 in progress)
Old May 4th, 2008, 05:48 PM   #103
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
" The most desirable situation is that all cylinders give the same or close to the same reading, and that reading is above 135 PSI. Uneven readings are not uncommon on worn engines, and as long as the difference between the highest and lowest readings are no more than 21 PSI and the lowest reading is 100 PSI or better, then the engine is acceptable. Greater differences between cylinders indicate worn or broken rings, leaky or sticky valves or a combination of all."
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old May 4th, 2008, 09:40 PM   #104
99v6stang's Avatar
any ideas what my problem could be?
Old May 4th, 2008, 11:03 PM   #105
moond0ggie's Avatar
1998 Mustang V6 5 spd.
moond0ggie is on a distinguished road
Originally Posted by stephen View Post
I can say from personal experience that inadequate fuel flow will make the engine lose power. After rebuilding my v6 engine it ran but was low on power. After a few days it died and I found the fuel pump was dead. After replacing the fuel pump it ran fine. So a weak fuel pump or clogged filter could explain the symptoms. When cars sit a long time while having engine work done the gas deteriorates and may clog up the fuel pump. I would check fuel pressure and timing.
Did you confirm that the fuel pump provides ample supply pressure?
http://www.moddedmustangs.com/forums/signaturepics/sigpic13601_6.gif
Old May 4th, 2008, 11:36 PM   #106
Lankolf's Avatar
97' 3.8 and 65' GT 289
Lankolf is on a distinguished road
Send a message via MSN to Lankolf
Your love of the Halfling's leaf has clearly Slowed your mind.
-Saruman, Fellowship of the Ring
I am the Lizard King, I can do anything.
-Jim Morrison, The Doors
Old May 5th, 2008, 07:48 AM   #107
99v6stang's Avatar
no i did not comfirm anything about the fuel pump, i think tonight i will just replace it with my focus svt fuel pump
Old May 5th, 2008, 08:34 AM   #108
The compression readings are good enough that the car should run well. Also they may improve if the engine was warmed up.
I would suggest getting the tool to set the cam position sensor. It's best to install it with the front cover off so you can line up the timing marks. If that's done it isn't engine mechanical or timing.
Other things to try are replacing the fuel pump as you said you planned to do, and if there are still problems, replace the electrical part of the cam position sensor.
Old May 5th, 2008, 08:36 AM   #109
Not what I meant to say. I meant align the cam gears as you showed in one of your photos, then install the front cover and cam position sensor using the tool.
Old May 5th, 2008, 10:15 AM   #110
Lankolf's Avatar
And the check engine light isn't on?
Old May 5th, 2008, 04:50 PM   #111
99v6stang's Avatar
no check engine light, im going right now to replace the fuel pump, and then install the timing cover and i already have a new electrical part of the cps, so ill try that and post and update of how that goes.
Old May 5th, 2008, 08:33 PM   #112
99v6stang's Avatar
alright, i put the timing cover back on and put on the new cps, so im going to wait a while to see if that fixed it, if not its on to the fuel pump
Old May 6th, 2008, 10:52 AM   #113
It's a good plan to do one thing at a time, so you know what fixed it.
This link shows how to go about removing and replacing the fuel tank.
http://www.moddedmustangs.com/2003-2...pump-swap.html
One tip is to replace the grommet on the fuel tank for the fill pipe. Ford recommends cutting it up with a utility knife to aid in removal. In installing it they said to use a little bit of "surfactant" to lubricate the bushing. I used dishwashing soap which worked fine.
Another possibility is the mass air flow sensor, but I think you will certainly have it running after replacing teh fuel pump.
Threads Similar to: just rebuilt car and now it wont run....
looking for a rebuilt t5 staggie 5.0 Mustangs 3 September 24th, 2007 06:43 PM
Rebuilt Engine oasr87 V6 Mustangs 24 July 7th, 2007 01:56 AM
to be rebuilt or not to rebuilt wildfaststang 5.0 Mustangs 3 July 30th, 2006 10:49 AM
