car running lean.... need immediate help
Old April 26th, 2008, 12:38 PM   #1
99v6stang's Avatar
99v6stang is on a distinguished road
okey 3 hours till i leave for prom and my car runs like shit. It appears as if it is running lean
Uncategorized - 100_1589
my other post has more info on the situation, but i just rebuilt the car and deleted egr and this is the problem
My car ---- (m112 in progress)
Old April 26th, 2008, 12:42 PM   #2
99v6stang's Avatar
here is some info about my car...
- F150 4.2l block
- Ported and polished heads
- Ported and polished lower intake
- Ported and polished upper and throttle body
-Morana racing 224/224 camshaft
- Hardend pushrods
- Comp Cam springs
- 4.10's and posi
- Mac longtube headers
- Mac hi-flow catted h-pipe and cat back
the car was tuned to run with all of this via sniper but not tuned for the egr delete. the car had these mods before the rebuild and worked fine. I not longer have the sniper tuner but have an xcal 3.
Old April 26th, 2008, 12:44 PM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
do you have a wide band 02 ?
Old April 26th, 2008, 12:44 PM   #4
99v6stang's Avatar
no
Old April 26th, 2008, 12:45 PM   #5
99v6stang's Avatar
but the car ran fine with these mods before, so im thinking egr delete, the timing, or i need a new tune for some random reason?
Old April 26th, 2008, 12:45 PM   #6
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
get one. you def. need one for your mods.
in the mean time try data logging with your xcal and it will give you a better idea of what the issue is..
Old April 26th, 2008, 12:46 PM   #7
99v6stang's Avatar
also i drilled out the egr ports in the lower intake and didnt weld them shut because the egr is blocked off anyways, could this be a problem? Uncategorized - 000_0023
Old April 26th, 2008, 12:47 PM   #8
99v6stang's Avatar
ive never used the xcal and have no instructions, what do i do with it?
Old April 26th, 2008, 12:49 PM   #9
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
that could def be an issue and to use the xcal simply plug it into the obd2 port and use the menu. it's pretty simple
Old April 26th, 2008, 12:51 PM   #10
99v6stang's Avatar
so those ports should be blocked off? i cant imagine why because there is an open hole through them anyways, i just made it bigger and the egr is capped off anyways, but im going to go try that with the xcal, do i have to run the car to datalog im assuming?
Old April 26th, 2008, 12:53 PM   #11
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
yes the car should be running.
the egr could have had a vaccum is what I'm implying.
Old April 26th, 2008, 12:56 PM   #12
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
If you don't have a WB how do you know its running lean?
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old April 26th, 2008, 01:01 PM   #13
99v6stang's Avatar
i was assuming by looking at the spark plugs, the xcal says unable to start data log
Old April 26th, 2008, 01:13 PM   #14
99v6stang's Avatar
okey i did some dataloging, how do i get it to the computer?
Old April 26th, 2008, 01:16 PM   #15
99v6stang's Avatar
where does this hose go? Uncategorized - 000_0032
Old April 26th, 2008, 01:20 PM   #16
99v6stang's Avatar
okey im downloading the live link software, what parts do you want me to tell you? can i post the whole thing online? and any ideas about where that hose goes?
Old April 26th, 2008, 02:11 PM   #17
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
can you up your fuel any with your x-cal? seems when you widened the ports your allowing more air from somewhere, add a bit of fuel.
NCMM #9
Old April 26th, 2008, 02:15 PM   #18
99v6stang's Avatar
is that user adjustable? ive never used sct i wonder if i can do that. This damn live link software wont let me install the drivers to datalog
Old April 26th, 2008, 02:17 PM   #19
99v6stang's Avatar
my car is tuned with sniper, so not if i tune it with xcal, would i need the entire tune? Not just be able to increase the fuel?
Old April 26th, 2008, 02:35 PM   #20
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Where is your sniper tuner?
I think your gonna have to flash the car back to stock, and then get a tune with the xcal!
Threads Similar to: car running lean.... need immediate help
Running Lean 1982matthew 5.0 Mustangs 2 April 23rd, 2008 04:01 PM
Car keeps running lean nicklo 5.0 Mustangs 8 January 29th, 2008 11:50 PM
running lean 91cobra5.0 5.0 Mustangs 26 January 24th, 2008 09:59 PM
Running Lean ROUSHME661 V6 Mustangs 22 November 30th, 2007 01:47 PM
My Car Is Running Too Lean, How Do I Fix It? SPEEDRACERCHICK02'92' 99-04 10 December 13th, 2006 11:54 PM
