My 2002 Mustang
Old October 22nd, 2006, 07:45 PM   #1
zimalatina's Avatar
zimalatina is on a distinguished road
Send a message via Yahoo to zimalatina
My 2002 Mustang
I have a knocking noise when I start the car. Then when it warms up the knocking stops. It has enough oil. I was wondering if this is normal? If it is why does it make that noise? If it is not, what could be the problem?
Old October 22nd, 2006, 11:10 PM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
is the knocking noise coming from the motor, the reason i say this is because before my smog pump stopped working it would make a similar knocking noise on startup while it was activated before bearing failure. however my pump was located in the passengerside fenderwell and could be mistaken as motor noise...
if it is coming from the motor, first thing i would do is scan the codes, then pull the spark plugs... could be spark knock? if plugs are good i would check the compression... then there are some other things to try.
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old October 30th, 2006, 02:23 PM   #3
zimalatina's Avatar
How do you scan codes and it seems to be coming from the passenger side of the car. What tool can I use to get the back spark plugs, it is hard to get any tool in their ...I haven't go the chance to even change my spark plugs b/c of failiure to get in there and get them out.
Old November 2nd, 2006, 03:35 PM   #4
zimalatina's Avatar
HEy where can I get some bad azz American Racing rims for my stang, for cheap of course?
Old November 2nd, 2006, 03:39 PM   #5
zdrainxx is on a distinguished road
Ebay, and knocks arnt a bad idea,look the same but are a lot cheaper.
Old November 2nd, 2006, 07:59 PM   #6
you scan for codes with an OBDII compliant handheld scanner, usually local autoparts stores like autozone will do this for free, or you can use something like an SCT XCAL2. you will need a sparkplug socket and a socket wrench to get the rear plugs...
Threads Similar to: My 2002 Mustang
2002 Mustang GT Newbomb 99-04 47 January 17th, 2007 05:09 AM
2002 mustang gt. owner momo0485 New Members Introductions 1 January 15th, 2007 10:38 PM
