Discussing Whining Noise in the V6 Mustangs Forum. So what I thought was my tensioner pulley...isn't lol. I've replaced the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 Mach 1
13.8@104
Whining Noise
I've replaced the tensioner pulley, conditioned the belt and now I have no clue what to try. The only way I know to describe is is a whining noise, it only does it sometimes and it usually occurs when I'm at idle. It's pretty loud and very annoying. I kept wondering if it was my cai, but I took it off last night and started it up, and it was still doing it so I have no clue. Like i can't even distinguish where it's come from. I might try replacing my alternator next... |
I don't really know your stang type too well but i think i would try a new belt altogether.
1995 Mustang convertible
There are so many things it could be. Are you at least sure that it's coming from the engine bay?
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
1994 Mustang v6
slower than your average snail
power steering pump maybe?
2003 Mach 1
13.8@104
Thats why I don't know what to do try, there are soo many things it could be. It's definitely from the engine bay. It might be the power steering, but I've had no problems out of it, I don't know if that matters or not though. I think I'm going to try a new belt and an idler pulley. I'm trying to work from cheep, up lol. Is there anyway it would be just the alternator pulley and not the alternator, or crankshaft pulley?
1994 Mustang v6
go get your alternator tested cause if im remembering right,if your diodes are going out it could cause a whine.....
01 mustang
Got to autozone and buy the stethoscope, you can put those things in your ears and then use the poker to touch the engine in any spot and you should hear the whine really loud vibrating through the end of it.
![]() LEAVE REP POINTS WHERE NEEDED!!! 2001 mustang V6 Dual Exhaust w/ H-pipe, Hi-flow CATS, original Flowmaster 40s, CAI,Tuner,Cobra Rims Silver Vehicle Club Member #3 |
V-SICKS
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
does the whine increase when you turn the wheel...if so then its you pump..
![]() The Devil & The Daily Daily-13.37@104.4mph V6- Stock bottom-439rwhp & 402rwtq 12psi 100oct built motor-497rwhp & 508rwtq 15psi pump |
01 mustang
could it be the compressor to? if its only sometimes maybe when a/c clutch engage?
V-SICKS
00 V6 & 09 GT
whining to me is probably- PS pump
anything else would be more of a squealing
2003 Mach 1
13.8@104
the problem is one i start looking for it after a few seconds it gone, then it will come back in a few mins and so on and so fourth. I'll buy an idler pulley and get my alternator tested Tues.
I had the sme problem....changed the belt and flushed the power stering!!!! Everything runs A1 now!!!!
The difference between Fiction and Reality??? Fiction has to make sense. -Tom Clancy |
1995 V6 Mustang
it could be your belt. it may have gotten stretched over time. also check your idler pully but that would be more of a squeak than a whine.
Rebuilt engine and transmission as of 2007 | MAC 2.5" Off Road H-pipe | MAC 2.5" True Dual Exhaust with Flowpath mufflers and 3" stainless tips | MAC Cold Air Intake |
Threads Similar to: Whining Noise
| Whining..... | Lt_Crazy | V6 Mustangs | 17 | March 28th, 2008 02:28 PM |
| Car Exhaust makes Whining noise | Gweedoe | 5.0 Mustangs | 9 | December 25th, 2007 12:51 PM |
| MSD replacement coil causing whining noise? | Redro | 5.0 Mustangs | 14 | May 30th, 2007 09:54 PM |
| whining noise... | El_Cangri | V6 Mustangs | 63 | May 27th, 2007 11:56 AM |
| Need Answer (Whining Noise) | Kope | V6 Mustangs | 8 | December 6th, 2006 08:45 PM |
