still throwing codes :(
Old May 5th, 2008, 12:17 PM   #1
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
Ok, a little while back i was throwing these codes:
P0135 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0155 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0741 Torque Converter Clutch Circuit Perf/Stuck Off
Now i changed all four of my O2 sensors to Bosch Premiums, and i also flushed the tranny and drained the torque converter and put in synthetic ATF.
After this was done, i cleared the engine codes...then disconnected the negative on my battery to reset the comp.....and a few days later the same code came back. Could the wires be bad that connect to the O2 sensors...and could i have a bad solenoid that is getting stuck on my torque converter?
Threads Similar to: still throwing codes :(
problems fixed, yet still throwing codes HELP shadow5403 V6 Mustangs 3 May 7th, 2008 10:26 AM
Engien light on...throwing these codes shadow5403 V6 Mustangs 2 April 6th, 2008 09:42 PM
Engine light on, but throwing no codes? shadow5403 V6 Mustangs 10 April 4th, 2008 02:24 PM
Throwing Codes! Garhfer 99-04 2 March 7th, 2007 09:21 AM
Computer throwing BAD CODES 00SoSlow General Tech 6 June 22nd, 2006 09:13 PM
