oil leak
Old May 6th, 2008, 12:06 PM   #1
wadepetersen is on a distinguished road
oil leak
My fuckin car is leaking oil
I have a few drops and shit under the engine
and farther back towards the muffler there is a nice nice puddle
I moved my car and you can clearly see a line of oil just by moving it 5 feet
I havent had a chance to try and find out what it is but do you guys have any ideas on what it could be
Old May 6th, 2008, 12:10 PM   #2
¡ʇsnq ɹo uʍop ǝpısdn
don't drive the car
rear main seal, the tail shaft on the tranny... maybe...
bad oil pan gasket or plug.
blown timing cover gasket... you choose... there could be more
Old May 6th, 2008, 12:13 PM   #3
i thought that it could be a bad plug or oil pan gasket
but i dont no there is no sign that the car is bad the check engine light came on the other day but it runs fine there are no signs of anything wrong except the oil leak
Old May 6th, 2008, 12:30 PM   #4
well if your trailing while moving the car your engine can't have much oil left... its a horrible idea to drive it till its fixed
Old May 6th, 2008, 12:55 PM   #5
stephen has a spectacular aura aboutstephen has a spectacular aura about
First is it oil or trans fluid. Trans fluid is red. Also check the fluid levels in both the engine and transmission to tell which is leaking.
Another thing to check for is a leaking oil filter.
Don't drive it till you confirm there is adequate oil!
Old May 6th, 2008, 01:12 PM   #6
i no that it is oil and i only moved 5 feet and that was becuase i had to get another car out and it has no oil in it
i thought it was werid the main puffle is under the car right before the muffler
and i wont be driving it i have to go look at it after school if i cant figure it out i got to go to a shop
Old May 6th, 2008, 01:23 PM   #7
I would replace the oil filter and fill it with oil then start it with it jacked up and see where it's leaking. It could be a leaking oil filter, which would then be fixed. It almost has to be oil under pressure to leak that fast. Pressurized oil goes through the front cover gasket, but I wouldn't expect it to leak that fast.
Old May 6th, 2008, 01:39 PM   #8
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
+1 DON'T DRIVE IT AT ALL!!!!!!!!!!!!!!!!!!! If you have to go to a mechanic, have it towed. If you're going to work on it yourself, you should completely fill it with oil. It is never good to have the car running without it. Plus, that will give you a chance to get under there and see whats wrong. If it is leaking like you say it is, it shouldn't be hard at all to figure out where it's coming from. Good luck man.
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old May 6th, 2008, 01:50 PM   #9
im sure i can find where it is leaking i will fill it and get under there clean some stuff off and see where it is coming from but then i got to figure out if i can fix it or not and if not how expenive it will be
but i dont think it is the filter why would the filter just all of a sudden come loose
Old May 6th, 2008, 02:16 PM   #10
The filter shouldn't come loose by its self. None-the-less at least check that the gasket is in place and the filter is tight. Things like this do happen.
In any case fill it with oil and see where it is leaking.
Threads Similar to: oil leak
oil leak under Oil filter Genevieve! 99-04 9 February 19th, 2008 08:30 PM
Oil leak? whtpny 99-04 0 November 16th, 2007 12:55 AM
Oil leak problem MnrlGry01gt 99-04 9 May 16th, 2007 03:18 AM
98 GT oil leak from the oil filter adapter??? Nissanguy8 96-98 8 February 9th, 2007 01:08 AM
Oil Leak Stangzilla 5.0 Mustangs 25 November 6th, 2006 05:00 PM
