Brake light warning
Old May 6th, 2008, 11:08 PM   #1
wannabeimportkiller's Avatar
2012 Race Red GT/CS
wannabeimportkiller will become famous soon enough
Send a message via AIM to wannabeimportkiller
Brake light warning
Sometimes when i accelarate the emergency brake light in the dash comes on. Anybody know what this means????
2012 Race Red GT/CS
98 GT-Gone
NCMM ORIGINAL
Old May 6th, 2008, 11:44 PM   #2
00v6newbie is on a distinguished road
Your car is wanting to drift? Hehe just joking. Mine never has done that, but at times when I floor it, random things flash on my dash also...
Old May 6th, 2008, 11:53 PM   #3
98stangv6's Avatar
1998 Mustang V6 SLOW
17.13@80.85
98stangv6 will become famous soon enough
Send a message via AIM to 98stangv6 Send a message via Yahoo to 98stangv6
check your brake fluid, its probably very low or empty
JAKE'S PIITB CREW MEMBER#4
Old May 7th, 2008, 01:44 AM   #4
Assassin_Dan's Avatar
1998 Mustang V6
Assassin_Dan is on a distinguished road
Send a message via MSN to Assassin_Dan
I doubt it has anything to do with brake fluid as the emergency brake is mechanical not hydraulic. It's probly just a bad switch or the contacts in the switch come togethor when you punch it.
Old May 7th, 2008, 01:47 AM   #5
stang300a's Avatar
2004 Mustang V6
stang300a is on a distinguished road
my 300zx did that and then a couple weeks after the alternator went out. u might wanna check that.
2004 Mustang 3.9L V6 with K&N intake, Dual Flowmaster Super 40s, Motoblue 42% Pulley, GT rear sway bar, drilled and slotted rotors, SCT tuner, Black FR500's 17 by 10.5 and 17 by 9, 4.10 motive gears and FRPP T-Lock.
Old May 7th, 2008, 10:59 AM   #6
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
how does the alternator fit in with a mechanical part while accelerating?:???????!?1/1
Old May 7th, 2008, 12:35 PM   #7
Timmano's Avatar
1995 Mustang V6
15.8@90.31
Timmano is on a distinguished road
The E Brake light DOES come on if your low on fluid. i know this cuz my lines busted and the light came on when my break fluid went low
Mods:
BBK UD Pulleys
Headers
Magnaflow with H pipe
85mm Spark plug wires.
K&N Air Filter.
Old May 7th, 2008, 12:38 PM   #8
Rico-mofos's Avatar
2008 Bullitt #890
slow
Rico-mofos is a jewel in the roughRico-mofos is a jewel in the roughRico-mofos is a jewel in the rough
Send a message via MSN to Rico-mofos
low brake fluid
BULLITT CREW #5 LT
GTB mufflers for sale
Old May 7th, 2008, 01:53 PM   #9
2012 Race Red GT/CS
thanks guys ill be sure to check that soon.
2012 Race Red GT/CS
98 GT-Gone
NCMM ORIGINAL
Old May 7th, 2008, 04:40 PM   #10
2000 Mustang V6
krispy is on a distinguished road
yep theres a sensor on the master cylinder that plugs in to see if you have enough fluid
Old May 7th, 2008, 04:42 PM   #11
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
also check to see if your E brake cable is a little loose.. if it is the light may come on when you hit a bump and the e brake rattles.
Old May 7th, 2008, 04:45 PM   #12
Senor Pointy Boots
atlacatl213's Avatar
2003 Mustang V6
Needs Track Time
atlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to beholdatlacatl213 is a splendid one to behold
Send a message via AIM to atlacatl213
Funny thing is that this also happens to me, I get it when my car is starting to warm up and then it stops after a while. Ima check my ebrake and brake fuild now.
"Weakness is not your weakness. You are what you grow into..." - Jon Gomm
Old May 7th, 2008, 05:31 PM   #13
stephen has a spectacular aura aboutstephen has a spectacular aura about
Some cars, but I don't think the Mustang, have a brake fluid level switch in the brake fluid cap. With this system, often, if the fluid is a bit low, it sloshes when you accelerate and makes the brake light come on.
Old May 7th, 2008, 05:47 PM   #14
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
It sounds like a loose connection or a short to me, but deffinately check your fluid level too.
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old May 7th, 2008, 08:05 PM   #15
2003 Mustang 3.8
slow
joparrett is an unknown quantity at this point
same thing happened to be. low brake fluid.
Jordan | 2003 Mustang 3.8 | SCT Tuner by VMP | CAI | Flowmasters | ZEX 75 shot
Old May 7th, 2008, 10:41 PM   #16
2012 Race Red GT/CS
Ok so yeh im thinking there is a short in the wires somewhere cause my rpm gauge has been acting up forever, and tonight on the way home from work it went all the way past seven and hit the little stopper and stayed that way and im pretty sure its still stuck there.
2012 Race Red GT/CS
98 GT-Gone
NCMM ORIGINAL
Threads Similar to: Brake light warning
warning light 2000roush 99-04 4 March 11th, 2008 01:11 AM
Brake light switch problem after upgrading brake booster black88 5.0 Mustangs 2 January 20th, 2008 11:41 PM
Brake light comes on smoke-em 99-04 9 September 26th, 2007 06:21 PM
Dome light and warning lights question. Buddydank V6 Mustangs 12 July 31st, 2007 01:46 AM
Warning light? tekt 5.0 Mustangs 14 March 11th, 2007 10:37 PM
