My Turbo install with Windstar upper swap - Page 3
LinkBack (1) Thread Tools
Old May 11th, 2008, 12:21 PM   #41
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
Originally Posted by ChrisJ View Post
Cant wait to see this in person...
BPS?
yea definitely once i get back down to school in august. should have all my lil projects done then too
SCT Mass Air Flow Sensor $200
Old May 11th, 2008, 12:39 PM   #42
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
Originally Posted by WLJohnson05 View Post
i need to do that too it still has the 10psi spring in it..any trick to it?
nope real easy
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 11th, 2008, 12:43 PM   #43
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
yea im waitin for monday to get here...i really want to get this goin...if i get home early enough tonight i might do some other stuff tonight...first thing to do is to get that windstar intake on which shouldnt be much of a problem. i just need to find a good piece of metal for the iac relocation which should be around the garage somewhere.
Old May 12th, 2008, 11:53 PM   #44
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
ok day one done...
i got the upper intake off and removed the egr except for the nut which is giving me hell...so i decided to go ahead and start stripping things down so i removed the front bumper and have the car up on jack stands. then since i couldnt get to the nut, i talked to chris and went to taking off the exhaust. i unbolted the cats from the headers but i couldnt get them to drop through the gap unless i could bring them back a ways. i then realized the only way that was happening is if i start from the back on the exhaust so i undid the hangers and loosened the clamps that held teh tip pipes and the mufflers but i have yet to be able to break them loose from each other. after messing with that for hours and not gettin anywhere, i went to working on the windstar intake and i built the bracket for the throttle and then i started bending the piece in the front but couldnt get it to the right spot where it cleared the intake...so im sittin on two problems right now that are holding me back...
Old May 13th, 2008, 08:35 AM   #45
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
do you have an aftermarket exhaust on already? removing an exhaust to me is breaking out the saws-all.
Old May 13th, 2008, 11:15 AM   #46
¡ʇsnq ɹo uʍop ǝpısdn
get a shit ton of WD40 ... and get a crescent wrench for the EGR... one pop to get it lose and then if just falls off
Old May 13th, 2008, 11:35 AM   #47
shadow5403's Avatar
^^^ comin from the guy who it took 3 days to install headers....
just playin OMZ,
i <3 u
Old May 13th, 2008, 11:42 AM   #48
three late evenings... its not like i worked on it every single day from 8-5 ... i put three to four hours in a night and called it done
Old May 13th, 2008, 12:10 PM   #49
obdnanr's Avatar
2003 v6
340/373 - yay for belts
obdnanr is on a distinguished road
ur going to use a windstar intake??
4.2L, gforce t5, 8.8, d1sc, other shit.
stang is down
Old May 13th, 2008, 01:32 PM   #50
shadow5403's Avatar
^^^shouldnt be too difficult to accomplish. Ppl have used the windstar with a vortech.
Old May 13th, 2008, 01:33 PM   #51
it wont shatter... and if it does just go back to stock
Old May 13th, 2008, 05:09 PM   #52
obdnanr's Avatar
2003 v6
well you don't just go back to stock. need different pipes and a gasket. maybe even a tune if their is a large air flow difference.
stang is down
Old May 13th, 2008, 05:11 PM   #53
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
thas the problem...i cant find the one we have...my step dad has been usin it and i cant find it, so i gotta wait till he gets home to ask about that
yea i tried the wd40 on the pipe to make it slip but no go it didnt budge at all...so ima cut it later on...its already unbolted from the headers and i have gotten the driver side header unbolted but am have trouble gettin it off do to the transmission fluid dipstick...im bout to go back out now and unbolt the passenger side header and just pull it and egr all out together. after that i think ima call it a day
Old May 13th, 2008, 05:12 PM   #54
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
it wont hurt it, they can handle boost, the max ima push it is like 10psi anyway so it should be fine in the long run
Old May 13th, 2008, 05:14 PM   #55
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
sounds like a fun setup brah. maybe you can hit the track with us on fridays when everything is done.
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old May 13th, 2008, 05:25 PM   #56
obdnanr's Avatar
2003 v6
if you already have the egr pipe off the header, all you have to do is unbolt two small bolts that connect to the upper intake, they are like 10/12 mm maybe 1/2 i cant remember. but its these two small bolts.
stang is down
Old May 13th, 2008, 07:18 PM   #57
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
penetrating oil ftw
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old May 14th, 2008, 01:33 AM   #58
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
no that wasnt the problem, my problem was getting it off the header...so i am workin around it and i got all but two bolts/nuts off the passenger side header and on the driver side header i got em all off but am having issues actually getting it out bc of the dipstick that is in the way. i finally found the sawzall and i cut the exhaust behind teh mufflers to get the tail pipes off. anyone know what the bar type thing is that runs directly in front of the radiator that runs up to the top from the bottom...it looks like it is just a support but im not sure...
Old May 14th, 2008, 02:02 AM   #59
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
also just to add...my wideband should be here tomorrow...pics to come.
Old May 14th, 2008, 10:27 AM   #60
modded232's Avatar
2000 Mustang V6 Vert
modded232 is on a distinguished road
When I replaced mine I just unbolted the other place the EGR attaches, disconnected the two rubber hoses that were on the EGR and the thing that those rubber hoses ran in to. That gave me enough room to pull the manifold with EGR still attached out of the car (even without having to remove my strut tower brace). After that I layed the manifold down on the ground used tons of penetrating oil, and the only way I could get it off was by putting an adjustable wrench on the EGR attachment, standing with one foot on the manifold so it wouldn't move, and then hitting the wrench with a concrete block. As an afterthought I should have just taken it to my work and used the acetylene torch to heat it up.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/69958-my-turbo-install-windstar-upper-swap.html
My Turbo install with Windstar upper swap - Page 14 This thread Refback June 4th, 2008 11:24 PM
Threads Similar to: My Turbo install with Windstar upper swap
Turbo mustang with windstar upper WLJohnson05 V6 Mustangs 41 May 4th, 2008 08:53 PM
Install Upper control arm.. 2006greyGT 2005 - 2010 7 March 23rd, 2008 08:28 PM
Removal/install of upper intake manifold Stang6899 V6 Mustangs 9 February 14th, 2008 12:54 PM
Before/After Windstar Intake Swap *Pics* One Bad Sixxx V6 Mustangs 46 December 18th, 2007 10:13 AM
Upper & Lower control Arm install stang94 5.0 Mustangs 3 January 11th, 2007 08:53 PM
