#21 |
I remember when my husband still owned his Blazer one of the O2 sensors went bad and the code actually said "Bank 1 Sensor 2" or something like that. Not that I could make any sense of it, but after failing emissions three times we wound up taking it down to Firestone to have it replaced.
I heard somewhere that you need a special tool to take it out. Is this true? The pic on Rock Auto looked like an outlet plug... |
#22 | |
#23 |
Wow, ain't that something... How much did that cost ya?
#24 | |
#25 |
get the MILs ?
#26 |
could always turn off the rear sensors.
#27 |
I would imagine it would be cheaper just to fix the damn thing. Don't they charge you like $300 to install a chip in the car to shut it off? They should be more precise with those trouble codes!!!!
....But then again that would make it WAY too easy... ....We don't want THAT to happen...
#28 |
I have FINALLY solved the mystery of P1413. It wound up being the smog pump after all... Five pumps and two bottles of WD40 later... Show's ya not to buy sh*t out of a junkyard. Not to mention, the vacuum solenoid was bad too. I pulled off the tube that connected them both and the pump wasn't blowing air; the solenoid wasn't sucking air either. I wound up dissecting these five smog pumps. Not only were they filled with water, but the motor was usually covered in about an inch of rust and the fan inside was all seized up. All I can say is find a junkyard that guarantees their parts. Ford Motors wanted $250 for the stupid thing, without shipping!!
In case anyone else is trying to decipher this code, check the vacuum solenoid first. It's A LOT cheaper, but chances are the pump is bad too. Blow through the steel end, and if no air comes out the other side it's toast... Replace it. For part 2, wait until the engine is cool and start it up. The rubber hose that connects the pump to the solenoid check valve thingy should be blowing air. If it's not, the pump is bad or it's not receiving power for one of various reasons. Chances are the pump is just rusted out or seized up like the five that I went through before fixing it. It runs on DC power so to check it, just pull it out (it's in the front by the passenger side bumper, there's only three bolts holding it in... (10mm)) and hook it up to the battery with two pieces of wire (strip the ends first). I'll betcha it doesn't turn on. Get a new one, test it using the same method, replace it and that should be the extent of the problem. Thankfully I never had to change the O2 sensors. Oh, and by the way, there is also fuse in the power distribution box called "Secondary Air Injection System". It's 30 AMP MAXI and about $1.99 from AutoZone. It would probably be a good idea to check this too before spending $100 from a junkyard for a pump you might not need. Google "P1413 fuse" to get a diagram, but I think it's the sixth one in. I hope this helps! If I get a chance I'll post some pics of the parts and locations. |
#29 |
Thanks for the update
#30 | |
heres the diagram...
#31 |
I know this is kinda off topic, but it seems that my car has developed a new problem.... The neverending story... Anyways, the car is making a honking sound when I step on the gas from a stop. It's very brief, but extremely irritating. It's louder and longer when the wheel is turned. I've ruled out the power steering pump, and I've received advice from many people. Supposedly you can't tap off the grease on any of the joints (who's dumb idea was that?!?) and the "Outer Tie Rod Ends" are a common problem with Ford vehicles. I don't know if this is problem, but it's a start right? Maybe if someone has experience in this department they could lead me in the right direction.
Unfortunately, I have no idea what an "Outer Tie Rod End" is, where I can find it on the car, how many there are, what it actually does and how to check/replace it. I'm hesitant to open up my Hayne's manual. Every time I do, I feel I lose a couple dozen brain cells... If someone has a picture of this thing or has had a similar problem, please let me know. Depending on how difficult it is to fix, I might opt to take it into the shop to get fixed... Thanks in advance... |
#32 | |
#33 |
This is probably a really stupid question but... What do you mean by the rack? And where can I find it? Does it have anything to do with the differential?
I think if it was the steering column then I would hear it on turns too... Oddly enough I only hear it when I come to a complete stop and then step on the gas. That's why I kinda ruled out the power steering pump. I generally don't hear anything coming from the front end of the car, it's more like the middle/rear. I figured it might have been a build up of brake dust on the rotors or something so I scrubbed and sprayed inside the tires and the wheel wells and it stopped for about a day or two. I was pretty excited, but when the sound came back I started to get a little worried and started to do some research on it. Some guy on Yahoo Answers said the struts might be dry and I should spray them down with lubricant. Does this sound right? Do you know if the struts are used when you step on the gas from a stop? |
#34 | |
#35 |
Mine is a 2000 3.8L Mustang. OBDII comes up with P0411 & P1414 (Secondary Air Injection). Folks mentioned smog pump and/or rear O2 sensors as possible culprits. Is there a way to tell if it's one or the other? I'd hate to have to replace a bunch of parts...
#36 |
Look Ma! My First Post!
Thanks I had this same prob
#37 |
One gear, GO!
![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Fucking christ man
![]() 2007 Mustang V6 Pony Package-SOLD 2000 Jeep Grand Cherokee Limited V8 4x4-SOLD 2000 Mustang GT-DD ROLL TIDE! NATIONAL CHAMPIONS 2011 |
Threads Similar to: Trouble Code P1413
| trouble code p1495 | DragonFreak | 96-98 | 5 | August 18th, 2007 11:02 PM |
| trouble code | 00vabchgt | 99-04 | 5 | April 17th, 2007 04:57 PM |
| Trouble code | dezzrat1 | 94-95 | 0 | April 17th, 2007 09:36 AM |
| Trouble Code | pdg36 | V6 Mustangs | 1 | March 29th, 2007 07:35 PM |
| Trouble code help | supu80 | V6 Mustangs | 8 | December 30th, 2006 10:10 PM |
