Trouble Code P1413
Strange...
For a while my 2000 Mustang was reading the code P0411, "Secondary Air Injection System Incorrect Flow Detected". The check engine light stayed on, but it did not affect the performance so I let it be... Now it's pulling the code P1413 "Secondary Air Injection System Monitor Circuit Low" and not P0411. Lately the car has been idling rough. What could this be? Please help... Mrs. Mustang (tnc112105@gmail.com) |
1999 Ford Mustang V6
more than likely your smog pump has failed for either two reasons... bearing failure or from water being sucked into the air inlet tube causing the motor to rust over. the smog pump is on the passengerside, in front of the wheel well. mine died also and threw the same codes, a replacement pump is around 180 from ford if i remember. the pump is only activated for the first 180seconds of startup to induce air into the exhaust manifolds to help promote buring of unspent hydrocarbon's which inturn improves emissions. the smog pump is also sometimes activated at idle momentarly. since we don't get smog tested where i live i removed it, and had the check enginge light turned off with aftermarket computer reprogramming from SCT. here is what the pump looks like:
![]() unfortunetly ford did not design any type of drain hole for water/moisture to escape once introduced into the pump, it basically sits in the rubber cup at the bottom until it evaps or rusts out the electric motor. personally i think ford should of owned up and done a recall, because this appears to be very common, unfortunetly mine died shortly after i crossed 40k miles..
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Thank you so much. I will make sure to change this, hopefully that will fix the problem.
Thanks again, Mrs. Mustang |
geez good to know
thanks for the post 99mustang232
ur so smart
good post, did not know this
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
this is a pretty common problem.
#7 | |
Okay.... So I change the smog pump, disconnect the battery terminals, turn off the check engine light for a whole three days... I'm pulling P1413 (Secondary Air Injection System Monitor Circuit LOW Voltage) again... and P1414 (Secondary Air Injection System Monitor Circuit HIGH Voltage)
... Needless to say I'm a little confused... I don't think it can make up it's mind... I'm pulling both these codes at the same time... Any ideas? Anyone? Thanks in advance, Mrs. Mustang |
if you replaced your airpump you need to have the codes reset.
disconnecting the battery does not work, sorry. mike e. |
MM's Resident Ricer
2006 Scion tC
13.001@113
Get the codes reset and if they still come up it is probably your rear o2 sensor it is common code thrower in the 2000 mustangs it won't hurt anything. A tuner from SCT will disable them if your worried about it.
I didn't realize that the Oxygen sensors were part of the secondary air injection system... Besides, I think they have their own set of trouble codes around the 1100's somewhere. The CEL really doesn't bother me that much, but I have to get my car inspected in about two weeks. I was really kinda hoping that the air pump was the root of the problem. It was quite an easy fix considering... Anyways, thanks for the quick reply! Eventually I'll figure it out.
MM's Resident Ricer
2006 Scion tC
13.001@113
p0411 is commonly thrown by the o2 sensor activating the evap system and it getting stuck. That was my problem for awhile.
i have the same code idk what the hell to do to fix it
Where is this O2 sensor? Most cars usually have four right?
MM's Resident Ricer
2006 Scion tC
13.001@113
umm i;m actually not to sure where the rear ones are located I haven't really played around with the emissions system Juggalo_X probably knows if you wanna pm him
#16 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
it is a 2000
#18 | |
Yeah, I had the codes reset and the CEL came back on an hour later. Its reading the trouble code P1413 again. I guess I'll change the O2 sensors in the back and see what happens. Does anyone know how to tell which one is bad? For $50 on Rock Auto it would be nice to have to buy only one.
#20 | |
Threads Similar to: Trouble Code P1413
| trouble code p1495 | DragonFreak | 96-98 | 5 | August 18th, 2007 11:02 PM |
| trouble code | 00vabchgt | 99-04 | 5 | April 17th, 2007 04:57 PM |
| Trouble code | dezzrat1 | 94-95 | 0 | April 17th, 2007 09:36 AM |
| Trouble Code | pdg36 | V6 Mustangs | 1 | March 29th, 2007 07:35 PM |
| Trouble code help | supu80 | V6 Mustangs | 8 | December 30th, 2006 10:10 PM |
