Discussing annoying stalling problem!!! grr! in the V6 Mustangs Forum. i have a 95 mustang 3.8 liter... it seems like after it gets warmed ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1995 Mustang V6
annoying stalling problem!!! grr! |
Sounds like it might be a problem with your IAC...or maybe your MAF(try cleaning it). When is the last time you had a tune up? How old are your spark plugs? Right now I'm thinking IAC though.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
Although, now that I look at this again...the sensor might fix it. If your sensor is bad, then your ecu could be getting wrong information about your AF ratio. Because of that it could be trying to correct this based on false information and causing the stall. In fact, this is even more likely since it happens after your car has warmed up(which is when the ecu starts using O2 sensor information). Put in the new sensor, I think it'll solve the problem. If it doesn't then look to what I originally said.
#4 | |
1993 5.ohhhh
14.47 at 96 mph
99 towncar siezed motor 1996 v6 mustang 5 speed fed in the a by a bronco 1999 v6 auto drive way paper weight 1993 5.0 5 speed http://i3.photobucket.com/albums/y51...thtrhtrhtr.jpg |
2000 V6 Mustang
^^^ +1
try the fuel filter first. |
1995 Mustang V6
it has brand new spark plugs and wires. brand new fuel filter. the output speed sensor is still not in yet. maybe it is giving a false rpm ont he tailshaft and its tryin 2 compensate for it. idk.. i gotta get it in.. i dont have access to a lift right now but i will this weekend i hope. thanks for the input tho.. i will clean the MAF and clean the iac pintle. see what happens.
1995 Mustang V6
by any chance do any of u know how the fuck 2 get codes out of a 95?... i go in and it keeps giving me P1000's which is system checks incomplete. i can read the history dtcs which is how i got the output speed sensor code. i know u have to do a drive cycle which is completely dumb but idk what it consists of in order to get codes out of it... it has a 16 pin connecter for obdII but it is still a 95 obd I car... sucks.
1995 Mustang V6
the code was output speed sensor circuit fault.. i measured the ohm value of the resister and got 243 ohms.. mitchell on demand says that it should be between 450-750 ohms.. thats all im going on for the bad sensor
Threads Similar to: annoying stalling problem!!! grr!
| Very Annoying Idle Problem | red99geetee | 99-04 | 6 | April 11th, 2008 01:09 PM |
| '01 Stalling problem | LanceD | V6 Mustangs | 11 | March 5th, 2007 01:15 AM |
| Stalling problem need help | Booger | 5.0 Mustangs | 2 | January 7th, 2007 09:07 PM |
| Stalling problem need help | Booger | 5.0 Mustangs | 3 | January 7th, 2007 01:53 AM |
| Stalling Problem | Mustang8719 | 5.0 Mustangs | 12 | July 27th, 2006 11:42 PM |
