Discussing Speedometer Cluster Assembly (Head) in the V6 Mustangs Forum. Hello, I have a 1994 Mustang, that needs its Speedometer head replaced. I've heard ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Speedometer Cluster Assembly (Head)I have a 1994 Mustang, that needs its Speedometer head replaced. I've heard that its both possible and not possible to use a Speedometer Cluster from another mustang and have the odometer read correctly, from mechanics in the area, as well as from Ford Mechanics.... Can I get a speedometer cluster from another 1994 mustang (base model like mine, or the GT version (150mph instead of 120), or even the cobra (160mph)) and swap that into mine? Will it set my odometer to what it should be? Or will I be forever screwed there? I'm just looking for my options because I want my odometer to be the correct mileage. I know I can get it done correctly from the manufacturer, but the new cluster costs $352ish. When I can get a used one for 1/3 or 1/4 of that. Anyone know? Thank you for your time. |
2004 Mustang V6
welcome to the forums.
Not exactly sure what you mean by spedometer head, I'm assuming you mean the gauges cluster as a whole. As long as your circuit board that runs everything isn't messed up you can steal one out a junkyard car and follow this tutorial and still have your odometer be correct. http://www.simcoltd.com/assets/pdf/2...xx_install.pdf |
#3 | ||
www.freewebs.com/wljohnson05 |
So, if I get a 94 V6 Cluster, will the odometer automatically reset to what it should be (what mine currently reads)? And will it continue to count mileage correctly? Also, would any adjustments need to be made to the speedometer in order for it to read correctly?
I'm just trying to decide if it is worth spending $490-540 to get it professionally done with a new cluster. To me that is very expensive. |
2004 Mustang V6
As long as you put the circuit board that is on the car currently it will read the current odometer.
#6 | |
Location: looking for free hand jobs in poland springs nebraska... silly gooses
all you have to do is swap out the individual gauge... there is a "Mother Board" to speak of that has some information encrypted into it that wont let the whole cluster assembly work with another car, but allows the gauges to be changed when ever desired
simcoltd has info on how to do this
slow car club - crew member 8 of 9
simcoltd's stuff is all 1999+. I need info for the 1994 since it has an analog display. Anyway I can get a digital display for it? Or will that even work?
Also, any ideas on where is the best place to look for the parts I need? |
#8 | |
its the same shit, same steps... connections will look different... and you will have to do some work with mechanical line
Threads Similar to: Speedometer Cluster Assembly (Head)
| Headlight assembly help. | 2007 GT/CS | 2005+ | 1 | April 20th, 2008 11:09 PM |
| Speedometer Cluster question | supermachone | V6 Mustangs | 9 | December 22nd, 2007 01:28 PM |
| E-Brake Assembly 85 GT | Nemesis | Want to Buy | 12 | July 8th, 2007 05:25 PM |
| Last and Final Speedometer/Cluster Question | 0di3 | 99-04 | 7 | July 2nd, 2007 03:05 PM |
| swapping '95 V6 gauge cluster to a '94-'98 GT cluster? | Alocatelli | V6 Mustangs | 3 | April 4th, 2007 02:38 PM |
