7.5 or 8.8" Rear End In My Car?
I have a 1997 3.8 Auto Mustang. It definitly has a regular differential in it, as the right wheel spins like mad while the left just kinda does nothing.
I am wanting to improve the rear end with gears and a traction lock, but am not sure if I have a 7.5 or 8.8 rear end. Is there a way to identify which one I have on my car? The reason I ask is that I am the 3rd owner. It looks like the car has had a couple things done to it before I got it, so am not sure if the rear end was part of this... thanks |
if your car is stock you have a 7.5...
11.47@120.58
Yes, you have a 7.5" rear end. They make trac-lok / posi differentials for your 7.5, or you could swap in an 8.8 from a GT if you wanted.
Thanks!!
I was thinking it would be the 7.5", but wasn't sure. While I don't THINK that I would blow up a nice built 7.5, I think I will visit the local salvage yard and see if I can grab an 8.8 to set up. Would I be able to take the rear from ANY v8, or would it need to be a GT? |
blow up an axle? more like bend or crack
find a v8 of your year
11.47@120.58
You can break an axle also Chris, though it's not likely to happen with a V6. Will some hard launches on slicks at the track to damage an axle (usually).
CyberPrey you'll need to find a rear end from a Mustang GT of the same bodystyle as yours. If you get one from another bodystyle you'll have backspacing problems with your wheels. |
#7 | |
Thanks Everyone
¡ʇsnq ɹo uʍop ǝpısdn
... if your really serious about getting a 8.8" ... you could look at online salvage places.... that is if you can't find a local place... im waiting for a response from an online place on prices if your interested at all
I found a local place that has a couple 96's and 97 GT's in their yard... He told me between $300-$400 for one, depending on if I just wanted the basic rear end, or with the complete brake system and the driveshaft....
I have one more question.. and this might be kind of stupid... my 'stang is a 97, v6, auto, Ac, pw, 4whl disk brake.... Is there more than 1 factory gear ratio in these?? I was told by a guy who thinks he is a ford guru that ALL V6 auto's came with a 3.27:1 gearing....... Anyway, I run 2000rpm at 70... If I go with a 3.73, that would put my RPM at 2281, or if a 4.10 it would put it at 2500, IF... IF... I have a 3.27... or are my calculations way off???? This site said the '97 came with a 2.73 in the base model (http://www.mustangforums.com/timelin...-ford-mustang/) which would (again, according to my possibly messy calculations??) put me at 2732RPM on a 3.73 and 3000 on a 4.10?? |
#11 | |
1999 Ford Mustang V6
14.79 @ 92.15
awhile back ford had a tsb out on the 7.5 due to noise, and some of the owners had theirs upgraded to an 8.8... the easiest way it to look at the diff cover
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
The 8.8 rear from a fox body 5.0 is a bolt in swap for your 97 car. You just need to switch the brakes over (4 bolts on each side). Also, the 7.5" rear axles are exactly the same as the 8.8" axles. The difference is the diameter of the ring gear.
I swapped in an 8.8 from an 89 fox body 5.0 into my 98 3.8. I re-used my original axles and rebuilt the diff in the 8.8 with 3.73 gears. The only axle housings that will not fit are the 99+ since they are slightly wider. |
Hmm, I have a noise from the rear end of my car also... It isn't the tires, the ujoints are all new, and I had the rear end fluid changed out for synthetic and the mechanic said all the bearings were good....
LOL, I wonder if ford will give me an 8.8 for my 10yr old car as I am the 3rd owner.. I have never had to deal with TSB's, does that work? |
How many miles are on your car?
Do you do a lot of peg leg burnouts? If you do a lot of one wheel burnouts, the planetary gears in the open differential will begin to gall rather quickly. This is not able to be properly checked during a fluid change since the large pin needs to be removed in the center of the diff. Just make sure it is not your tires. I've also had a set of u-joints go out after less than 1000 miles. If you have a lot of miles and do lots of burnouts, either the planetary gears or the ring and pinion gear might be worn. But, this is expensive, relatively speaking, to the tires and u-joints. Try not to jump right to the expensive repair unless you are sure. |
I'm in the exact same boat as you...
partially modded 2000 v6 auto when I got it...not sure what all was done to it.... AFTER much searching and price comparisons I have found it best to just go ahead and get the 8.8 rear end out of a GT.... Only thing I need to know from someone is what GEARS come stock in a 99-00 GT....????anyone know?.. Should I get the GT 8.8 rear and then put in 4.10's??? take care and good luck on your search... <thinks>DAMN why didn't they just put T-Lok in 7.5's?? Who wants to spin one back tire and get all crooked off the line...?? That should be a safety issue...lol</thinks> |
#17 | |
14.79 @ 92.15
yes you should put 4.10s in the 8.8 and i never got crooked off the line with an open diff, but the traction is much more evident- harder to spin both as opposed to just one.
You don't get crooked off the line with an open differential. That is a characteristic of a locked rear axle (traction lok) because both tires are spinning. With an open differential one tire stays planted while the other one spins which effectively holds the car from going sideways.
The car itself has about 97,000 on it. The tires it came with were goodyear eagle gt+4's on the factory wheels. I replaced them with 16x8 wheels (cobra knock-offs from americanmuscle.com) and 'Fierce' brand 225/55R16's. As I don't like buying tires, I try to not spin the wheel (as in one... heh heh) very often.
It "sounds" like the noise is coming from the drivers side of the car, I was thinking of the outer bearing on the rear end, but I went ahead and replaced that and I still have the whine... |
Threads Similar to: 7.5 or 8.8" Rear End In My Car?
| 8.8" rear end... | singe | V6 Mustangs | 7 | July 26th, 2007 06:40 AM |
| 9" rear end | 69_5.0_stang | Classic Mustangs | 2 | July 26th, 2007 06:25 AM |
| ford 9" rear | mustangrebuilder | Classic Mustangs | 1 | March 10th, 2007 11:57 PM |
| does a 9" rear end fit in a fox? | redalert89 | 5.0 Mustangs | 12 | March 7th, 2007 09:19 PM |
