Discussing Over Drive... in the V6 Mustangs Forum. So I just got into a debate with my shop about the overdrive in my ...
Old May 9th, 2008, 07:43 PM   #1
poindexter18's Avatar
'95 mustang sixer
*Shrugs*
Over Drive...
So I just got into a debate with my shop about the overdrive in my stang. It's an AODE tranny from a 95 mustang. Original one in the car, and all maintenance work done and so on. But i wanna know about that O/D button on the side of the shifter. Last I checked it turns off the overdrive setting, but he said I should never turn it on unless I'm above 60. I was thinking, if that's the case why would the Overdrive Off show up with the CEL and Check Battery lights? I was under the impression that with this transmission it was always supposed to be on? Anyone know one way or the other?
-poindexter-
License Plate says it all.
Old May 9th, 2008, 07:44 PM   #2
Avaric3's Avatar
1999 Ford Mustang
the world may never know
it should a lways be on unless youre towing a heavy load which will probly never occur with your mustang
COMING SOON- FRPP Aluminum Drivshaft, VAP Windstar Upper Kit, VAP 1/2" Intake Spacer, MMR Front Coil-Overs, Eibach Sportline Rear Springs
Old May 9th, 2008, 08:46 PM   #3
2004 Mustang V6
or if you are going uphill at a speed that it keeps shifting between 3rd and the overdrive thus overworking the trans
Old May 9th, 2008, 10:32 PM   #4
2004 Mustang V6
16.39 @ 83 w/o mods
yea, overdrive is just the last gear, and you should only shut it off if, like 04dsgv6 said, your tranny keeps shifting between third and od up a hill. If your crusing around at like 35, your car will shift into overdrive while driving at a constant pace, ie no hills or heavy pedal pressure. It saves you gas and at 4 dollars a gallon, id tell that doosh he needs to find a new profession.
2004 Mustang V6
Saleen 18s
4:10s
T-Loc
75 Wet Shot
1989 Chrysler Lebaron GTC 2.5 Turbo DD
Originally Posted by HMUSN View Post
once you go sonic blue everything else looks like poo
Old May 9th, 2008, 10:56 PM   #5
qwik48r's Avatar
08 GT
yea he thinks your a dumbass... i would have got offened if he told me it turns it ON... wow wow wow... what kind of shop?
everyone's a gen-ious around here...
08 Black GT 5sp. Hurst.Pypes.Motive.Nitto(wrong kind, and for sale!!).Mobil1
02 GMC Sierra ECSB. TR.Pacesetter.CompCams.Crane.
Richmond.Eaton.K&N.Performabuilt.FlowCrapster. Nelson Tuned!
Old May 10th, 2008, 12:11 AM   #6
RavensChild's Avatar
1998 Mustang Coupe
Amazing
what overdrive does is change your ratio to 1:1.
Car Tuned By Joe At TrickTuners.
Originally Posted by 96GTRagTop View Post
u have no idea the amount of porn i go through in one day
I have made Zip ROFLMFAO, have you?
Old May 10th, 2008, 12:45 AM   #7
'02SilverBullet's Avatar
The guys are right... Leave OD on always. The only exception I could think of with a mustang would be in a moutainous area with lots of hills and valleys. For sure turn it off in those areas. A tranny that keeps trying to shift to OD going up a hill will over heat and KILL the trans!
Mods Include......
BBK CAI
MM Caster Camber Plates
Baer Decalla Drilled and Sloted Rotors
w/ painted callipers
Hypercoated 18x9 FR500 Rims
Eibach Pro Kit Lowering Springs
More to come.....!
Old May 10th, 2008, 05:43 AM   #8
'95 mustang sixer
*Shrugs*
HA!!! I fucking knew it! I'm totally getting reimbursed for the tranny work they did without my go ahead....
Stupid car still being in my mother's name despite her selling it to me. I'm lazy.... I should change the paperwork though. ^_^
-poindexter-
Old May 11th, 2008, 01:40 PM   #9
1998 Mustang Coupe
Amazing
you cant turn it off in a manual can you? just stay out of 5th?
Old May 11th, 2008, 02:02 PM   #10
2004 Mustang V6
What kills the auto trans with OD is it shifting repeatedly heating up the trans. In a manual, its simple. Just do not shift repeatedly back and forth, I sincerely doubt you will be changing gears on an incline anyways.
Old May 11th, 2008, 08:55 PM   #11
1998 Mustang Coupe
Amazing
^yeah i dont shift on steep inclines
Threads Similar to: Over Drive...
Would you drive a..... Regency 2007 The Clubhouse 22 March 27th, 2008 06:59 PM
Okay last one with drive by 07stanggt 2005+ 8 March 4th, 2008 09:48 AM
anyone drive a White Thunder The Clubhouse 5 October 15th, 2007 01:33 AM
7 tooth drive gear or 8 tooth drive gear for my 98 GT manual Blue98GT Modular Mustangs 1 January 6th, 2007 07:27 PM
i cant drive 55 Invictus Videos 1 December 22nd, 2006 12:24 PM
